Disston No. 3D Saw Vise Question
Dave (Arlington, VA)
Hi All -
Does anyone know if there is a tool catalogue on-line that describes the use of the Disston No. 3D Saw Vise (with saw file guide). I picked up one recently and while I might be able to figure it out (i.e. how to set it up for a given rake, fleam and so forth) I thought I would see if there are any catalogue's on-line. I have done a quick search, but so far I have come up dry.
I appreciate your help on this.
Regards -
Dave
Re: Disston No. 3D Saw Vise Question
Marv
Hi Dave,
I don't know of any instructions on how to use the saw filing guide, but here are some pictures of a vise and guide I sold on eBay a couple years ago. The pictures show how the guide is adjusted for filing. The guide doesn't have any gauges or marks to set the angles to. You'll just have to determine your fleam and rake angles using a protractor. Once you get it set up, you can make some marks on the guide so you can return to those settings. Keep in mind, when filing a crosscut, you'll have to reset the angles when you turn the saw to file the opposite direction. The pictures show how the guide is set for filing from left to right and filing every other tooth. Then turn the saw around so the handle is on your right and then you'll file the other teeth from right to left. If you have a saw that is already sharpened with the fleam and rake angles you like, use that saw to set the guide to. If you don't have a good saw and are filing an old beater, for a crosscut, use a 15 degree rake and a 25 degree fleam angle. Other angles can be used, but I have found that these angles are good for general purposes.
Good luck,
Marv
Marv
Hi Dave,
As an added note.....ultimately, you'll probably want to learn to file without the guide. The guide is combersome and you have to move your saw more often to file the full length of a blade. It works ok, for a saw that is properly filed to begin with and is only dull and needs to be touched up and made sharp again.
It can be used for filing a saw that has badly filed teeth but you need to have some other basic filing knowledge regarding how to recondition bad teeth in order for the guide to be of much use. Having said that, when you do have the ability to recondition a beat up saw, you'll be at a stage where you won't even want to use a guide.
Have fun,
Marv
Thank you, Marv
Marv -
I appreciate the pics. When I posted my question I had not yet figured out that whoever had previously owned this saw had put the file angling mechanism back together the wrong way. Now with it corrected, things look a bit more intuitive.
As you suggest, I am sure the proof will be in the tasting. I have sharpened a couple of saws previously and while they looked a bit ragged, they all cut much better after having been sharpened. Still, it always seemed to me - because I am just a hand tool hobbyist - that a guide would be a good thing. Nonetheless, I hear you. It may turn out to be too fussy. I'll just have to give it a try and see how it goes.
I assume that if a guide was such a fantastic idea, more saw vises would come with saw file guides. Still, this No. 3D is one hefty saw vise - and much better than my previous one!
Again, thanks!
Dave
Todd O. Cronkhite
Hey Marv, what a great idea, a saw vise on it's own stand! Talk about portability. Defiantly a "why didn't I think of that" moment. :\
Marv
Todd,
LOL...the stand was only for picture taking for eBay. Just seemed to be the thing to do at the time.
Marv
