Maintaining bevels over time
Wiley Horne--So. Calif.
Hi Frank,
I admire those who can use multiple bevels and keep track of them. Are you able to manage the third bevel so that it gets 'erased' at every sharpening? Do you camber plane blades, and how then is the third bevel managed? And when do you regrind the hollow--when the secondary is about 1/16", 1/8"...? Plane blades and chisels the same way? Or different?
What I find is that getting the blade sharp right now is not the issue. The issue is managing the edge efficiently over time and over many sharpenings. And maintaining camber.
I can only get into a work rhythm if my methods are simple. It helps me to keep in touch with things if I use a hollow, and hone one bevel, which is self-jigging with the hollow, at an eyeballed 25-27 degrees (chisels and plane blades), and regrind when the honed bevel exceeds about 1/8" wide.** With the one bevel, I can manage camber on try planes and smoothers by hand pressure on the edge; on fore plane or jack it's a more complex rolling motion, but the single honed bevel keeps it as simple as possible.
Something I have done in the past is have the overall hollow at less than 25 degrees, and then hone to whatever matches the work best--25 degrees, 27 degrees, 30 degrees, whatever, none of these angles measured, but approximated by eye. In other words, uncouple the hollowing from the honing angle. But when I do this, I tend to lose track of the last angle I put on the tool. So it just amounts to a rounded-over bevel for practical purposes, when I go to resharpen. So I've left myself a problem. This is why I just do the simplest thing, even though I'm pretty sure it's not technically optimum on any given sharpening.
Could you say a few words about how you manage bevels over time? This is not meant to be challenging--I know you are a thoughtful worker, and have developed methods that will be useful to others.
Thanks! Sorry to be so long-winded.
Wiley
**There are a few Japanese chisels I can't bear to hollow, but these blades are easy to maintain with one simple primary bevel. And many Japanese chisels I do take to the Tormek, because it won't draw the temper, nor make a deep hollow.
