stanley 79
stanley 79
stanley 79
JimG
Has anyone got any tips on using a stanley 79? Is there a specific angle to sharpen it? Should I take some off the top of the dado first, then adjust the depth for a lower cut? I don't seem to be having a lot of luck with it.
Thanks,
JimG
Re: stanley 79
Re: stanley 79
Bruce, a MN Galoot
I just got one a couple months ago and used it the other day for the first time. My dados seldom are deeper than 1/2" and I see no problem with that depth. I used the 79 to clean up some that I cut at 3/8" without problem, even adjusted the pin side of a sliding dovetail. Of course with the sliding dovetail it wouldn't reach all the way to the bottom but that was not difficult to fix with a good chisel. I will say, however, that if I were to do a lot of sliding dovetails, I'd just get a dovetail plane.
Mine came sharp enough to use so it hasn't needed tuning up yet. Can't help you there, but that bevel does look pretty low, maybe less than 25 degrees.
Re: stanley 79
Re: stanley 79 *LINK*
Roger Nixon's Traditional Tools website has a one-page instruction sheet, not much help but a couple of good ideas, link below.
The 79 is kind of the ambidextrous version of Stanley's 98/99 side rabbet planes, so looking at Lie-Nielsen's instruction sheet for these might help. They indicate that the honing angle is 25 degrees, with a skew of 30 degrees. Some of the references I've seen recommend honing off the very tip of the skew, because, as you increase the depth of cut, you also push the iron down below the sole of the plane ("below" in the sense of holding it upright; this is a confusing plane to discuss), and, ideally, you don't want it acting as a spur at the bottom of the rabbet you're cleaning up. This is more easily seen than described.
Both "The Hand Plane Book" and "Planecraft," my two go-to books for plane use, are rather casual about discussing side rabbets, seeming to think that they're pretty doggone simple to use; like you, I've found that it's not quite so intuitive as those authors think, but I haven't used it enough to offer much helpful actual advice.
Stanley 79 instruction sheet or catalog page
Re: stanley 79
Re: stanley 79
JimG
Thanks! Actually, you gave me quite a bit of info.
JimG
