LV Twin Screw Vise--using the '1/2 link'
Wiley Horne--So. Calif.
Warning: This post will be understandable only by LV Twin Screw Vise users, but there are enough of them that it may do someone some good.
A few months ago, I installed my third LV Twin Screw Vise. Thought I was an expert. But this third vise has been doing an annoying thing because of a faulty decision I made at the initial installation. I finally figured out my mistake, and just fixed it. I want to relate the indications and the fix, in hopes it may help someone.
This particular vise is the 24" model. But the span I needed was about 19"+ or - center to center between the main vise screws. I didn't think much about it, just went ahead and drilled the jaws for the main screws, installed them, and then went to LV's instructions to see how many links I should remove from the chain to make it fit.
As luck would have it, my drilling was such that (now I'm making these numbers up) 48 links was too short, but 49 links was a little long. So I made it 49 links and thought no more about it. Went ahead and did the chain install and started using the vise.....
Well, the vise worked, but from time to time it did something that neither of my other ones did--every now and then there would be kind of a weird lurch, or momentary loss of traction; then the vise would instantly catch again and be normal. Except that the slippage, or whatever it was, was misaligning the screws little by little.
Now I admit to being dumb, but I'm not stupid. Yet I could look right at the chain as this odd lurch occurred, and it was so fast like instant coffee, that I couldn't make out what was going on. Plus I needed to get on with things, so I just lived with it.
Finally, it occurred to me in bed before I went to sleep one night, what was going on. When the chain is a little long--not so long you can take a full link out, but just a little long--it can furl up on the slack side as you spin the drive sprocket. In other words, as you spin the drive-side sprocket, the bottom of the chain will be taut, and the top will be slack (or vice versa). Also, the chain has a little 'body' in it; it's not perfectly limp. So when the chain is a little too long, the slack side has enough body to start furling up--enough to furl it's way all the way around the drive sprocket--and every link of the chain will find its way to the next tooth on the sprocket. Yes, the chain will actually rear up and reposition itself on the drive sprocket so that every link gains a tooth. This all happens so fast, you can't actually see it.
As I start getting my head wrapped around this, I then realize 'Oh, this is why LV includes a half-link in the vise kit'. Get out the instructions--yep, there's just enough slack that I can use this half-link to shorten the chain by a half link. Take out a full link, put in the half link. We're talking about shortening a 19" chain by 3/16". But it makes all the difference. Now the vise works perfectly.
Two suggestions relative to LV Twin Screw vises:
1. If you're having weird slippage as described above, test the chain for slack (as shown in the LV instructions). You may need to shorten the chain by a half-link.
2. And more important....At the initial installation, if you're not using the full length of the chain, be smart about how you place the twin screws. Pick a center-to-center distance for the screws which corresponds to a specific number of links in the chain--48 links, 49 links, 52 links, whatever--but don't use a center-to-center distance which falls between links. It's asking for misery. Incidentally, each link of the chain represents 3/8", so there will surely be enough flex in your installation that you can place the screws to correspond to a round number of links.
That's my story for tonight.
Wiley
