REAL MILK PAINT
Pegboard solutions
Pegboard solutions
Steven Antonucci
Pegboard solutions
Steven Antonucci
I am reorganizing my shop, and I have decided that I want to have some commonly used woodworking tools available on my pegboard behind the benches.
Can some of you share the custom "hangers" you've made to fit a standard pegboard for things like planes and other handtools that may not have a hang hole?
Thanks
Steve
Re: Pegboard solutions
Your planes don't have hang holes?  Easy to fix!
Hank Knight
Steve,
I have peg board on my shop walls. My shop is in my basement and the walls are poured concrete. I mounted the peg board on stringers and made the top stringer half of a French cleat. I have open cabinets that hang from the cleats and last year I made a rack for my bench planes that hangs from the cleat. They hold a lot of weight.
Notice my cabinets have no backs. They hang flush against the peg board so I can use peg board hooks inside.
Another trick I learned is to attach custom tool racks to the peg board with figure "8" brackets used for attaching table tops and short lag bolts sized to screw into the peg board holes (I think they are 5/16 X 3/4 lag screws). This makes a strong attachment. I have, for example, all my lathe chisels and my hand saws in a custom racks mounted to peg board this way and they are solid as a rock. I don't have any photos of the attachement, but I can take some if you're interested.
Hank
Steven Antonucci
Chisels will be another problem
Steven Antonucci
part of my overall vision is to have a space that is dense, without looking cluttered. I don't want to have a lot of different things thrown together, since that's what I just tore down. The area should be something that conveys "unity" for how I work today (which is a lot of carving, some hand work, and the staple tools we all use.)
Not sure if that's clear, but it's where I am aiming for...
Thanks
steve
P.S. if you could take a pic of the chisel rack, that would be great...
steve mackay
I'm hang'n planes with hammer (two "prong") hangers. Machine fences go on the same. Combination squares go on two hooks horizontaly so the don't swing around. 'Bout as creative as I've gotten.
Nuth'n fancy . . .
steve mackay
I keep "better" chisels in a box. these are my beaters so they're handy. Could have embelished a bit I guess.
Again, could have been more decorative but I got tiered of rooting around for my spade bits.
scott grandstaff
Re: Pegboard solutions PIX
scott grandstaff
Ok, here is my trick
I make racks that fit standard pegs themselves. You drill for the peg and epoxy them in at the proper distance to fit standard holes in the board.
Then you can move the whole rack around at will when it comes rearrange time.
You can do chisel or screwdriver or pliers racks and they hang off standard pegs.
If you get the heavier duty commercial pegs you can load them right up!
Here is a Perfect Handle screwdriver rack (drivers done in walnut/polished shafts and maple/blued shafts for contrast, btw). :)
If you look in the second pic you can see pliers and screwdrivers (there is another large pliers rack just out of the picture stuffed with small sized pliers above), plus a tiny rack for very small hammers. The larger racks are about 3' feet long. There are dozens of screwdrivers and well, a couple dozen pliers at least, and some are very large pliers/shears.
If you squint into the second pic harder.........you can see my working punches and cold chisel selection too.
yours Scott
Wiley Horne--So. Calif.
Great photos, Scott!! Thanks! I could look at your work and tool collection all day long. Trufe.
You need to show us those wrenches sometime, in between projects.
Wiley
What I Did
David Miller from Iowa
Not seeing the pics
Bob Hackett
And I`d really link to.
No evidence of any pics being posted thru my browser(firefox).What am I missing here,any suggestions?
MB
That's way too neat and organized!
Hank Knight
That's quite the wall David...
Scott Burr in Ben Lomond CA
Ya think you have enough drawknifes :D
What's the plane to the left of the box scraper?
Re: Pegboard solutions - plywood
Thomd
I just think pegboard looks so terrible and isn't all that practical. I use wooden boards or paintable maple ply. I make individual racks for each tool. They don't swing or move etc... for chisels I figure out how deep the rack needs to be to accomodate the handle and metal rings etc... Then I drill minor diameter holes through the wood for each chisel. Then I ream the holes so that they are a good fit for the ferules. I have been lucky that all my chisels seem to fit the same reamer hole. Then I saw away wood from what will be the front, and I plane it down until I get to the point where I can fit chisels in from the front. I screw these chisel racks right to the boards, and I hang them from French cleats that run about 80 feet around my shop.
I try not to use solutions in the shop that I would not produce in the shop for clients or the home. For the most part I don't have clients but I think that way anyway since clients require a consistent approach that I owe myself just as much. I think often when one sees that really organic and beautiful shop it is because the whole thing is working in the same direction. Like I have planes because I varlue a hand planed finish... but I hang them on peg board!!! And as a bonus the organic solution often uses cheaper materials or even leftover scraps. But, hey, that's just me.
I have pictured these racks here before, unfortunately since giving up the internet connection I can't just throw up pictures any more.
Second boards and cleats approach.
Bob Hackett
The biggest advantage to hanging things on a board and cleat is that you can take the whole board anywhere in the shop and hang it where it will be close at hand.
As stated,the racks/holders are an excellent use for all those offcuts and small scraps that would go in the stove otherwise.
Why would you want to use hand tools and build with real wood only to hang your tools from an engineered semi-wood product(pegboard is no more wood than MDF is) and cheap wire hangers? Pegboard just looks cheesy,IMO.
Break out those design skills and wood scraps and make some racks that show off what you`re capable of.Then festoon those finely crafted racks with your carefully restored trophy tools on boards you have hand finished and can be proud of!
Hang those fine signature tool boards from strong cleats and be happy in the knowledge that those tools are secure,well displayed and handy at a moment`s notice wherever in that well equipped shop you may be. :D
Leave the pegboard and imported cad plated wire hangers to Wal-mart and The Dollar Store.You`re a cabinet maker now,not a discount house or a wire sculptor for Pete`s sake.
I gotta go lay down now,mumble,mumble...
MB-Highly chapped in Maine. ;)
To the left of the box scraper *LINK*
Looks like two Surforms to me, the "plane" variety, one older and one newer - right, David?
I gotta say, you'd better hope that the Reelfoot Rift doesn't start dancing again, or those planes balanced on two long rods are going to be experiencing serious gravity. Unless, of course (shut your ears, Scott), you've got magnets involved somehow.
Such a great name - sounds like a dance step
At least.....
Marv
Bob,
At least he painted it white and didn't trace around each tool with a black marker. And he used the 1/4" thick pegboard so he could use the heavy duty hangers. Makes for a nice open display wall for his tools.
I have 30 ft. of pegboard and it's still brown. I couldn't count the number of times I've had to move pegs around and rearrange stuff over the past 30 years.
The only thing that is constant, is change.
Marv
In defense of peg board
Hank Knight
Peg board is seriously ugly, but eminently practical. Marv is right, the only constant in my shop is change. I'll bet I've changed the organization of the tools on my peg board walls three dozen times since I put it up. Almost every new tool acquisition prompts a reorganization to make a place for it. Often a better idea about where to put stuff comes along and prompts a reorganization, as does an idea for a new bracket to hold chisels or layout tools. I'd love to have a pretty workshop with wood panel walls, but panel walls don't allow the flexibility to move stuff around like peg board does. Boards with cleats offer some flexibility, but peg board allows you to move things in 1 inch increments and is much more flexible. In my shop, practical trumps pretty. I've looked for something I could live with that's more traditional and attractive than peg board, but I haven't found it yet.
Hank
You can have a permanent arrangement
Bruce, a MN Galoot
when you stop buying tools. But who wants to do that? :D
Better than pegboard
Bob Hackett
There is an alternative to pegboard and I`m sure you`ve looked right at it and not seen it for what it was.
Many of the upscale clothing shops have gotten away from that ugly pegboard by installing wood grained MDF with a special horizontal slot cut at intervals.It looks a little like ship lap siding and can use regular pegboard hangers as well as special fixtures and wire mesh bins.
During the time I was on heavy duty pain meds and almost lost what was left of my mind I actually brought some home and was considering doing away with my wood racks/boards in favor of it.
Luckily I came to my senses and brought it back to the dump a few months later after I kicked the meds.
I shudder to think of what I almost did! Just one jump from the shop cat going for a mouse running along the ledge of the foundation and all those wire hangers acting like springs and launching those trophy tools in her wake.Then listening to them as they impact the concrete floor.
Financial ruin in 60 seconds or less.The horror,the horror! :(
Re: Better than pegboard
Hank Knight
Bob,
Thanks for the suggestion. I think I'll stick with my ugly white peg board. Your description of the cat and mouse chase is just too chilling! :O :D
Hank
Sometimes....
Marv
Ya just wanna rearrange the furniture. :D
Marv
are you and my wife related?
Bruce, a MN Galoot
Solution to "ugly pegboard" . . .
steve mackay
And you KNOW what it is, right ? Right ?
MORE TOOLS to cover that unsightly stuff !
Re: In defense of peg board
ThomD
With no disrespect to other choices...
"Peg board is seriously ugly, but eminently practical."
That can be said about anything. For instance, some people, like me, prefer to have wooden planes (got both but prefer wood), many of which are for an individual purpose. Other people like to have one plane with a million adjustments. So the question is which approach should your furniture support? What's the messaging you want to create. How would a customer feel if he was in a maker of say Brian Bogg's stature and all the chairs in use were metal and fiberglass? I mean it isn't a contradiction really there could be reasons why he uses those and his clients buy the wooden ones he makes (not a true story of course).
Now if you take it a step further than that, which person is one? Is one the person who likes solid simple, organic stuff, developed to a very high level. Is one hurting the fabric of one's personality by allowing stuff like pegboard in? Is it a contradiction one simply hasn't dealt with, because it was unnoticed. Of course people can like all kinds of stuff tearing off in all kinds of directions. An example of this kind of thing is in that thread where Wiley is tossing the power tools. Should see my shop. Appointments are available when I get it cleaned up in say 2030.
Other than that. The method I use is not fixed, it would be relatively easy to reposition things, since I can just unscrew the racks or split them off and go again. On the other hand. Since making these racks for chisels and saws, I haven't wanted to change them. I put enough effort into them that I actually like them. In fact, really, if we hadn't started out with pegboard, I think I could be suffering similar criticisms relative to those who make massive cabinets for their tools, though it just so happens I prefer the aesthetics of my current choice. But I could see why others would disagree.
Another thing is that while I have fixed racks I also have some peg racks, not pegboard. I got these from pics of Odates shop. They are rows of horizontal dowels onto which one can lay tools and yet dust doesn't accumulate. They look fairly nice, and can accommodate a huge variety of stuff from hacksaws to chisels to block planes. And they work well for floating tools in and out the space without having to designate them a fixed space.
Pam Niedermayer - Austin, TX
That's also my favorite approach, but haven't implemented it yet, for many reasons, but one being I thought dust would indeed accumulate and another being that I haven't yet figured out precisely how to incorporate tambours to cover the tools with wood when not in use. So, why doesn't dust accumulate?
Pam
