Off topic - water heater and math questions
These are related questions.
We're planning to replace our water heater and are dithering between a tankless heater and a moderate to high efficiency tank-type heater. Condensing tank-type heaters, for instance, although they're more expensive than the tankless, seem to have the same annual efficiency. Experiences and opinions welcomed.
On to the math: one of the issues with the tankless heater is the minimum water flow requirements. For instance, one Rinnai model I looked at requires 0.4 gallons per minute (presumably in the hot water circuit, not total flow) to light off the burner. We try to conserve water - our experience of the last 20 years has convinced us that California will have periodic droughts - and it's possible that some of our hot water uses are too low-flow. One example is showering: once I get wet, I turn the water down fairly low for soaping up, before bringing it back up somewhat for rinsing off. I can measure the total water flow in each state, but it's not all hot water, and I am flummoxed how I would calculate what percentage of the flow is hot water. Available tools are a one-gallon bucket, a clock with a second hand, and a kitchen thermometer. Any help will be appreciated.
