An electric shooting board
Paul M.
This project was very overkill, but I thought the title alone would grab some eyeballs. 8)
I recently needed a shooting board for joining top and back plates for guitars. In the lutherie class I took, they had a light table for inspection. I thought... Why not combine these two into one jig?
I got a cheap 1-bulb 24" fluorescent fixture, and built my shooting board around it. Here are some pictures showing this shooting board with the plexiglass top. I built this jig pretty tall as I wanted adequate air gap over the fluorescent fixture so that the plexiglass wouldn't warp from the heat. This required raising the ramp for the plane up pretty high too, which is why there is the large stack of plywood on the right side. Please ignore the large bandsaw kerf on the far right hand side where I tried to cut off some of the excess material and ran into an embedded screw that I used to glue up this monster. That kissed one bandsaw blade goodbye:
Here's the jig in use. Both plates are stacked together and planed at once. A plane about 1/2 the length of the material is plenty for jointing. This is rather poor quality cedar (LMI 2nd), but it's use is just for a jig anyways and it won't be used as a soundboard.
Plates before... Wow look how that 1/4" gap pops out:
During... This is only about 1/32 gap, but it looks huge due to the backlight:
And the final plates are perfectly jointed. Total elapsed time was probably 10 minutes including stopping to take pictures with my cheapo camera that refused to focus on material with low contrast.
Re: An electric shooting board
wilbur
That's a really clever idea!
Even with the heat from the fluorescent light taken care of, how does plexiglass hold up over time to warping? I've seen many things made with plexiglass that had a noticeable curve in it, but those things either might not have been plexiglass or were made with thinner material than in your box.
Paul M.
I guess I'll find out whether this warps over time. I only made this a few months ago. I leave it hanging on the wall when not in use so there is no weight on it that would cause it to warp during storage. And it only gets used for a few minutes at a time, so the light is not on for very long. So I'm guessing it will hold up OK.
steve mackay
I don't know now. Over the long run overkill tends to pay off ! I've gotten fed up trying to hold something, spent an afternoon building some elaborate fixture, and still be use'n it years latter 'cause it winds up holding more than I made it for. I'll bet your box ends up doing a lot more than it is right now !
Interesting design
A proper hand tool design would, of course, employ mice holding tiny little candles, but that would increase heat problems.
This seems highly efficient: plane, test, plane, test. Good idea.
bugbear
Does your camera have "focus lock" (often a half-touch on the shutter)?
If so you can place a focus target (I've cut a crossword puzzle out of a magazine!) on your subject, lock your focus (AKA pre-focus) remove the target, and click.
Yeah, it's a pain.
BugBear
Paul M.
Hi Bugbear,
I have a couple of rulers in the last picture to hold down the gentle curve of the plates that allowed light to pass through when the plates were not held down flat. They also allowed the camera something to focus on so I could actually take the picture. This was an olympus point-n-shoot that I keep in my bike gear for pictures during rides. It was bought for it's indestructability and not for its quality photo capabilites. It struggles for low-light close up photos.
Re: Interesting design
Paul M.
Mice holding tiny candles... I don't think that would last very long with my shop cats prowling around. The spider count has dropped dramatically in my shop since the cats started joining me out there. Not much gets past them.
nice - "whatever it takes"
bugbear
