Syringes in woodworking
Jack Guzman from Maine
I want to get a syringe to use with hide glue. The purposes will be injecting glue under veneer bubbles,injecting alcohol into joints to loosen them up and injecting glue into tiny cracks as well as any other uses that may arise. Where does one go to get a syringe? Do pharmacies sell them over the counter? Is a regular insulin needle the right tool or do they sell other kinds? Does the point of the needle require modifying in any way?Thanks---Jack
Re: Syringes in woodworking
Re: Syringes in woodworking *LINK*
Pam Niedermayer - Austin, TX
I suppose there are lots of sources; but I bought one from LV, part of a chair repair kit. They have a set of glue syringes, follow the link below.
Pam
LV glue syringes
That was quick
I wasn't expecting anyone else up this early(or is it late?).Thanks Pam---Jack
Speaking of chairs,
You might want to try to catch this week's Antiques Roadshow, part 3 of the Denver series, first 5 or 10 minutes. There are a couple of beautiful chairs, laminated, mid to late '50's design by John Pyle, produced by George Nelson. They look real simple, but the curves are to die for in the first, and the second is an exercise in defining a chair.
Pam, who's up because it's real quiet and I try to take Baldric for a walk when no one's around, don't have to put his leash on...him or me. :)
Re: Speaking of chairs,
My favorite time of day.I just spent about an hour in the shop. I let my dog Arrow run at 4 .She loves to explore the neighborhood and there is no traffic on this gravel road in the early morning.---Jack
Jim DeLaney, Austintown, Ohio
Re: Syringes in woodworking - Tractor Supply
I buy mine at Tractor Supply, in the Veterinary Department. They're much cheaper than any woodworking source. Six 5cc syringes are about $3.00, and the needles (sold separately) are about the same price.
For hide glue, a #16 gauge needle works well.
Jim D.
Stephen Shepherd
Stephen Shepherd
Jack,
I use used insulin needles for injecting alcohol in hide glue joints to desiccate the glue allowing the part to come apart. The needles are very fine and will go down a tight joint, but I have broken them off trying.
For hide glue I need to keep the syringe and needle in hot water to keep it thin enough to go out the small hole. I have tried others including veterinary needles but they are too large, at least the one I had.
Stephen
Feed store
My local feed store carries them. I've never purchased any, and Stephen's comment about the syringes being too large makes sense: the local store seems to favor syringes suitable for horses up to elephant size. But you might check that possibility out.
Jerry Nicholson
I picked up some syringes at the pharmacy hoping I could push some epoxy through them. Didn't work - the viscosity of the epoxy I was using was much too high. I didn't have any trouble buying the syringes at the pharmacy but we have been doing business with them for years and I told the pharmacist what I wanted to do. In the past, I have used medical syringes for oilers (filed down the tip so I wouldn't stab myself!) but I found that the seal deteriorated rather rapidly.
Jerry
Re: Feed store
Warren in Lancaster, PA
My local farm store sells at least a half dozen needle sizes in little plastic cases. I use several different sizes with the same syringe depending on the viscosity or the size of the opening where it is to go. Most people who handle livestock buy syringes and give shots.
Wiley Horne--So. Calif.
Hi Jack,
I agree with Jim D. that a 16 ga needle is good for hide glue--I'm thinking Old Brown Glue.
Sometimes I manage to lift up a piece of appearance wood, and have it hanging by a 'hinge'. Need to get a dab of glue under it without breaking it totally off. In this situation, I have found that 18 ga needle is good for yellow and white glue and the like (all the Titebonds, for example). I have used 20 gauge in warm weather, and when I really wanted a small needle tip, so as not to break the 'hinge', but you can't get more than a drop or two up the needle at that gauge. So 18 ga is a better recommendation.
I haven't done the alcohol injection, so will not comment on that.
For all of the above, I think a 3cc syringe is plenty--that's a lot of glue to inject. So it's useful to buy some 3cc syringes, and then have various needles, all of which will fit the syringe. I have always bought from the veterinary supply house, KV Vet. There are many others, of course. I tend to buy one brand of syringes and needles, so I'm sure that all the needles fit the syringe.
From KV Vet, here are the needles:
http://www.kvsupply.com/KVVet/product_family.asp?family%5Fid=212&gift=False&mscssid=138AE6AE3E6A481BBFEA5B75B9BDDF38
and here are the syringes (as I say, I like 3cc):
http://www.kvsupply.com/KVVet/product_family.asp?family%5Fid=211&gift=False&mscssid=138AE6AE3E6A481BBFEA5B75B9BDDF38
Note that this stuff is not very expensive from veterinary supply houses.
Hope this helps,
Wiley
Stephen Shepherd
Insulin needles are 29 gauge, 12.7mm
Stephen Shepherd
Correction on gauges!
Jack and all,
This is embarrassing, but maybe it'll save someone some trouble if I fess up :| . The gauge sizes I listed above were based on sucking the glue right up the needle into the syringe--the way they do it at the vet's and at the MD's office, just before they give you a shot.
But reading Stephen's post just now, it finally clicked in my head--wait a minute, why are you sucking glue up the needle??? With the needle already on the syringe, just take the bottle of glue--Old Brown Glue or PVA glue--pull the plunger out of the syringe and load up the syringe with glue, put the plunger back into the syringe, and squeeze the glue out! Duhhh :) .
When I load the syringe directly, rather than suck glue up the needle, a 20-gauge needle works OK with Old Brown Glue or Titebond. At 73 degrees. I'm going to keep these syringes loaded, and see whether the glue stays ready to use over time--seems like it should, since there is less air access into the syringe than into the glue bottle it's normally in.
Geez, this is embarrassing to admit, but hope it will help someone. By the way, there is some marginal benefit to the Luerlock needles, since there's no way they'll get squeezed off as you apply pressure.
Wiley ..... discovering the obvious
Lots of good info---Thanks
Re: Speaking of chairs,  *LINK*
I just found a PBS page devoted to these chairs:
Laminated chairs designed by John Pyle
