Making liquid hide glue.
Paul Kierstead
So, I finally got some nice crystallized urea (very pure). Fired up the glue pot last night, mixed in some urea (15% by weight, i.e. 100g of glue + 15g urea). Mixed is up some, poured it out into a bottle. It didn't gel up as fast as regular hot hide glue. Left it overnight.
This morning, the 'liquid' hide glue had gelled up very firm. I placed the bottle in some hot water (ala Old Brown Glue) and it did indeed re-liquify readily. I tried some out, but will say it re-gelled on application somewhat; less so then hot hide glue at this temperature would (it would be unusable), but not easy to use either (gelled much faster then OBG).
I'd call this some success, but not a success . So, the questions, in case anyone out there actually has answers, is what I do different on the next test. I guess the first problem is causal.
- Not enough urea? Guidelines seem to be 10-30%
- Urea didn't dissolve in. Melting point of urea is >135 C; however, I assumed it could be dissolved in hide glue. It isn't necessarily easy to tell if it did.
- Needs cooking? This is some kind of protein modification (I think), so perhaps some cooking is required?
Anyone done this and have some thoughts?
Also, I'd be curious how Franklin gets a liquid hide glue that doesn't even need warming.
