Door glass installation
Jack Guzman from Maine
This is slightly OT. I'm rehabbing an old pair of entry doors to install in an old house. The doors are built using wedged through tenons.The wedges are on the outside of the tenons. I disassembled the doors so I could clean out old paint and dirt and tighten them up.There doesn't appear to be any glue at all in any of the joints. The doors came apart easily(with reverse clamping) because everything was dry. I plan on glueing all surfaces with hide glue and tightening up the wedges as well as pegging the joints.I have two questions that I hope someone in this forum can help me with. First,am I wrong in glueing these joints?The dry wedges have been sufficient for years.I'm just concerned that the glue might restrict movement.
The second question is illustrated by the sketch enclosed.The door was stripped of all paint and moldings on one side.There was no glass in the opening. The panels are as shown,7/16" thick floating in 7/16" deep grooves.The opening for the glass has 2 1/8" wide strips in a similar groove. On the one side that has moldings,the molding is flush with the strip in the window opening and there is paint on the top edge. I need to know how to install the glass. In the third sketch is a guess on my part. Any ideas on how to finish the bare side of this door that would also accomodate the installation of 1/4" glass?----Jack
