Building the Carousel Shooting Board Fence
Re: Building the Carousel Shooting Board Fence
Dave Chatham
Derek, not that I will ever get around to building this but, how did you layout the miter holes which you allude to explaining later. It seems they need to be precisely set from the face of the fence since a single insert locks all settings. Did I miss it?
Dave
Hi Dave
Yes, you missed it. Of course it is more likely that I could have been clearer in my description ..
Two pictures: in the first I showed a template I used that marked off the holes ..
What you must remember is that the design is built around a circle. The pivot pin is the centre of the circle, and the holes lie on the circumference. So all you need to do is mark these off using a protractor (as I have on the template).
Here is the second picture. It shows the lines from the pivot pin (note that the "square" position hole is 6mm here and is enlarged to 8mm at the end to create the micro-adjustment).
Hope this clarifies matters.
