ADVERTISE HERE - FREE TRIAL
Question on sharpening block plane blades...
Scott Burr in Ben Lomond CA
Or maybe I should say "How do you sharpen yours?"
Just curious here, I have always sharpened my block plane blades flat across.
No camber, no eased corners. I've never had any problems with planing grooves or such.
So, How do you sharpen yours?
Re: Question on sharpening block plane blades...
James Watriss
Since I don't typically use my block planes to plane surfaces, there's no real need to camber anything. And on my rabbet block plane, it would be silly to knock down the corners.
Since Low-angle/ bevel up planes are technically classified as block planes, I'll say that I do camber those a bit, but I use them much differently.
scott grandstaff
scott grandstaff
I sharpen nearly everything with a barely discernible camber.
Its 100 times easier to let a tiny camber happen, than trying to keep it away.
So I just let it.
Obviously you have fuss over the corners in a rabbit or other grooving plane.
But in any kind of smoother or jointer I just let the very corners get slightly damaged in sharpening.
Nothing really intentional as to rounding, just cavalier treatment of the corners as I go.
Once again, its easier this way.
Lazy mans way
yours Scott
I'm with you,
Bruce, a MN Galoot
cambers just seem to happen. Little ones, but that's okay for the most part.
Chris Friesen
I'm still a beginner, but I have the extra ball and tote that turns the LV block into the equivalent of a #3, so because of that I camber it like a smoother and have a second high-angle blade. Doesn't seem to impact its use for normal purposes.
ThomD
I do some square and some cambered. So for instance when cutting the end grain on the plane blacks I am making during the 30 Days of Plane Making challenge, I don't want any tracks from the edges. When doing fly rids I want flat surfaces. I have about 7+ of them, but most of the action is with three of them of which one is cambered.
