Animation of Some Chinese Joinery *LINK*
charlie belden
I'd found this page before but lost it when I lost all my bookmarks.
The attached link has links to three examples of chinese joinery - animated so you can see the parts and how they go together.
Why pieces using chinese joinery doesn't show up in woodworking magazines is a mystery. There's a lot you can do with mitered frame and panels and triple mitered joints shouldn't be ruled out as too difficult now that loose tenon mortise jigs and handheld mortisers (Festools DOMINO) make the traditional mortise and tenon mitered joint fairly easy.
Found any other sites with images of chinese joinery?
chinese joinery animations
Re: Animation of Some Chinese Joinery *LINK*
Pretty cool
This is the clearest demonstration I've ever seen of the interlocking nature of the joints.
People who can do those well are clearly layout artists!
thomd
Cool. How strong are these kinds of joints (many tiny parts). Do they depend on being cut in rosewood, etc...
charlie belden
Wouldn't recomend using them with BORG douglas fir or lodge pole pine - but with cherry, walnut, oak, beech, ash or other harder "hardwoods" they would do the job.
Which brings up another difference between Chinese and "Western" joinery. If you think about Stickley or Greene & Greene type A&C joinery, and component size - Western pieces are really, really, really over designed from a structural strength perspective. Relative to classic Chinese pieces, Western furniture is MASSIVE. And even when larger dimension components are needed in a Chinese piece, the VISUAL size of that component will be made so it APPEARS smaller - and more delicate and refined.
The joinery does what it NEEDS to do - and not much more. And I suspect that they did some TORTURE TESTING to confirm the strength of the joinery - before delivering it - to someone who weighed maybe 50% more than the craftsman - and who, if "displeased" by the piece - if it broke in use - COULD cause the craftsman and perhaps his family - to be killed - or exiled. If you worry about Trial Lawyers and Product Liability are an issue here, imagine the risk management in Imperial China.
You have to remember, woodworking in China evolved VERY slowly and introducing something NEW was VERY risky. So Chinese joinery and furniture design EVOLVED, very slowly, perhaps something new added every four, five or ten generations. The modern pieces I have are using basically the same mitered frame and panels - with integral tenons rather than separate splines and the same triple mitered corners, also with integral mortise and tenons.
Now granted, they could make more delicate pieces, with finer joinery, when they worked with really strong, hard woods, but the joinery methods work with other woods - just adjusted for scale.
Chris Scholz
Chris Scholz
The old Chinese used a great variety of wood species in their furniture.
Softwood was often used when the piece was to be lacquered. According to Mazurkewich, Shanmu (fur) is said to have been very popular in the Fujian province.
I have tried my hand on a small step stool using Borg lumber. My woodworking skill is very basic and the joints I cut were ugly, huge gaps. Nevertheless, the step stool was rock solid.
So, no, you don't need rosewood. You can cut this kind of joint in just about any wood you can find.
where can one find books on Japaneese and Chinese
Wayne Carson
Chris Scholz
Re: where can one find books on Japaneese and Chin
Chris Scholz
Wayne,
I don't know much about Japanese joinery.
Curtis Evarts, the pre-eminent scholar in Antique Chinese Furniture, has published extensively on the topic. His website features an extensive list of books mostly with the collector in mind.
Here you can find an annotated collection of books that is focused on the woodworker.
Chris
Pam Niedermayer - Austin, TX
For woodworking with Japanese tools, start with Toshio Odate's Japanese Tools.
Pam
Hi Wayne, Check out this book...
Scott Burr in Ben Lomond CA
the Complete Japanese Joinery. It's should be pretty much anywhere (Amazon, etc.).
