James Swan and Co. Extra U.S.A. Countersink
Stephen Shepherd
I picked this up today for a buck, the flutes on the countersink have two bevels and the tang is unusual, never seen this configuration.
Stephen
Stephen Shepherd
Stephen
Re: James Swan and Co. Extra U.S.A. Countersink
Interesting design. I suppose the extension beyond the square taper is for use with a three-jaw or other chuck designed for round shanks? Seems awfully short for good gripping, but an admirable attempt, especially compared to those later designs that required you to cut off the square taper to use the bit in a round-shank chuck.
thomd
Is it for metal? I use the metal ones on wood, for that mater.
Stephen Shepherd
Thom.
According to the literature the rose-head is for brass and other soft metals, the flat countersinks are for iron and steel and the snails are for wood.
I use the rose-heads for wood as well but they can chatter on hard and soft grain.
Stephen
