Re: Furniture repair
scott grandstaff
Can't help you with a book, but my own experiences...........
Keep a stash of veneer around. No glue ever invented will hold on old sloppy furniture joints. Tenons or spindles, whatever.
When the wood has shrunk, you need more wood!!
Soak some veneer and then use rubber bands and ordinary wood glue (titebond, elmers etc ) on spindle tenons for instance.
Even soaked the veneer will crack a little on small stretchers and spindles.
So be it, nobody will ever see.
When the glue dries just cut the rubber bands free and you scrape/sand or file the tenon until it is a hard tight fit.
Glue that, draw it up with clamps and you can count on it.
I also keep artists paints around for finish matching. There is no way I am going to match some screwy color with stains or glazes etc,
and I'll lose my mind trying!
But a small pallet and some mixing and judicious application, mostly "dry brushing" technique, with a bare minimum of paint, you can hide almost anything.
yours Scott
