new sole for Wooden plane
Rick snyder
Hello,
I purchased a wooden plane over the weekend. The sole needs to be repaired. My first thought is to repair the missing chunk of wood and then apply a new sole. I would like to make the mouth tighter in the process. the following are some questions about the process...
1. Is walnut a decent choice for the new sole? (color contrast)
2. What glue should be used?
3. How do you go about creating a tighter mouth on the new sole?
4, How thick should the new sole be?
If there is any other infomation I need for this process, please advise.
Thank You,
Rick
Re: new sole for Wooden plane
chuckbeck in cent il
I made a scraper plane out of walnut a few years ago, not a great idea, you want something really hard that will wear well. If it is domestic, Osage wears well, hickory will do it, hard maple does well, but doesn't hold much wax. There is also the import route with lignum vitae if you don't mind eating blades, or cocobolo, or any dalbergia you can get ahold of. Boxwood, dogwood, ironwood..
If you haven't done this before go to the library. My favorite assistance with this is reading Mr. Krenov describe his intentions. Then again, he always fires my spirit.
\chuckbeck
paul womack
Whilst a different wood (form the original) would give colour contrast, and a harder wood than the original would improve wear, ANY other wood than the original could potentially cause warping issues under humidity changes. Even if you use the same timber, it is important that the new sole and plane are stabilised at the same moisture content.
BugBear
Look to the articles here
Bob Hackett
Bob Smalser and others have articles about how to rehab wood planes just a click away in the box to your left.
As for wood,go to the nearesr contractor that does custom decks and ask him for a straight grained(preferably close to quartersawn) offcut of Ipe` (sometimes called greenheart).
If you can`t find any locally PM me and I`ll send some if you foot the postage.
MB
Stephen Shepherd
Stephen Shepherd
No. 1 has been addressed, I would recommend beech which is probably what your plane is made from.
No. 2 Hide glue is the only choice, either hot or the ready to use liquid hide glue.
No. 3 and No 4 when I replaced a sole on a smoothing plane I calculated how thick the plane should have been before wear by triangulating down the mouth. I then made the sole thicker than necessary, glued it on and after it dried, I chopped down through the throat to form an open wedge shape at the throat. I then removed wood from the bottom to open the mouth to just where I wanted the opening spacing.
Good luck.
Stephen
Jerry Draper
The book "Making & Mastering Wood Planes" by David Finck answers all your questions.
Disclaimer: WAY not a wooden plane guy, these are just general observations.
You say the sole needs to be repaired - what do you mean? Is there a chunk missing? Is the mouth wallowed out? Is the sole far, far out of true?
Before applying a new sole, you might consider whether patches will do the job. As I understand it, there's a long tradition of patching the mouth of a wooden plane with a glued-in patch just in front of the mouth, not over the whole sole. You might consider whether patches will restore it to function and glory, and whether that will be less work than applying a new sole.
scott grandstaff
scott grandstaff
How bad is this sole really?
And how special is this plane a new sole is warranted?
Resoling is not the cakewalk to do, that it is to talk about. Its totally possible but it better be some spectacular plane or family heirloom or something.
Your best shot at resoling is to take an equal amount off the old plane body as you are adding the new sole.
Or else you'll be making a new wedge too and probably recutting the mortise that the screw rides inside of, assuming a 2 piece blade n chipbreaker plane blade outfit.
See what I mean?
Letting in a new mouth piece though?? This is easy.
Walnut isn't hard enough for throat duty. Well most of it isn't.
But you only need a scrap of whatever you use. Many many choices. Just start at beech and go harder from there in the lineup, and you'll be happy. Rosewood, coco, osage, mesquite, ironwood, bocote, pick your poison.
Make your patch about 1 1/2" long, ahead of the mouth. You want some bearing. Some guys like to cut it pointed (50/60 degrees??)
in front for a smaller mortise.
A dovetail shape might be cool. You could make a fleur-de-lis out of it if you want, or any decorative shape. No need to make a plain block, is my point.
Make your patch, (around 3/8" thick or a bit less is pretty standard that I've seen), lay it on the sole and trace around it with a very sharp pencil.
Mortise out the hole. Remember to leave that line!!
Cut right up as close to the line as you can. If you can't get the patch to wiggle down in, only then pare a hair more wood where you have to.
Naturally you will be making the throat too tight, and filing open last.
Too tight doesn't mean zero.
I have made that mistake before. DOH
Your blade is probably 3/16" thick remember, so make it ~1/8" so you can get your files in there. :)
yours Scott
Peter Evans
I resoled a coffin smoother just for the experience, I was not lacking smoothers. I used a thin piece, bit under 3/16" of Brush Box, a very hard and dense Australian hardwood. BB wears very well.
Where I came unstuck was in drilling out the mouth - the BB is rather brittle and I blew out some wood around the mouth by being too casual with my drilling. So ... work carefully and slowly and creep up on the mouth opening.
Cheers
Peter
