Biggest yet ! . . .
Biggest yet ! . . .
Biggest yet ! . . .
steve mackay
I know this is old hat for folks here but I'm just thrilled this actually worked perfect the first try thanks to everything I've learned at WC ! Thanks to all ! REALLY ! ! ! Although I've "joined" before this was a BIG one (for me). I needed 20" wide to fit an Abrams, HEMMT Tanker and HEMMT Wrecker on for an order from The CAV. Well, I guess they don't let red oak grow that big any more. Gave up looking, bought me a 10" and drug it home without much confidence. I KNEW this was to big for the TS so started geting out those hand planes I've been restoring and useing once in awhile. Didn't really take all that long to get my edges to match with the 5 1/4 but I did have doubts. Since its going to get stained I was worried about glue in the join showing through any tiny gaps and the stain not sticking. Glued it up, clamped and hoped for the best. Before surfacing I did two "daddo & spline" joints across the bottom since there won't be any structure underneath. Surfaced with the #5 and sanded. Finnished the ends with the #289. Chamfered all 'round with the 90 1/2 useing that neat method of the pencil lines that was posted a couple weeks ago (thank God !). Wiped it down with the damp rag just now and can't find ANY glue shining through ! YIPEE ! The final is 21" x 34". Have to look pretty hard to find the seam. Sorry for rambling but LOML is away and I had to crow to someone ! This stuff really does a number on the ego doesn't it ?
Re: Biggest yet ! . . .
nothing like it
David Miller from Iowa
When I was a bit younger, I used to plane boards just for the fun of it - no project in mind. Guess I still do, when testing a tuned plane
Re: nothing like it
Todd O. Cronkhite
Ahhhhhhhhhh, the Sweet taste of Victory!! Congratulations!
I don't understand the purpose of your project, but I do understand that you successfully accomplished your goal with Handtools and that you are Thrilled about it, and therefore, I am Thrilled for you. :)
Mmmmm, Yea, OK, Steve...
Scott Burr in Ben Lomond CA
What cha talkin bout? In all your excitement you gave us gibberish ;)
I know it has something to do whit the models you make, Yes?
Also, what's a Dado & Spline joint?
Anyway, congrats on your accomplishment!
Correct term ?
steve mackay
Sorry, the thingie to upload pics isn't there any longer and I guess I'm not bright enough to figure it out. Yes, its a base for all three models. My term "daddo & spline" probably has a correct name. If I cut daddos across the width about 2mm deep and wide then glued in a 2x2 stick what would I have ?
Probably a crack waiting to happen :-(
GolfSteve in Calgary
Hope it doesn't happen, but I've seen how a cross grain support like that can crack a board as the board tries to expand, then contracts as the humidity varies season to season.
Hi Steve, do you have a profile?
If so look for the " Upload embedded file:" right above the box that you type your message into hit the "Browse" button and upload the pic. The neat thing about this is you can now upload multiple pics in a post now :)
If not make a profile and let the fun begin!
Sure do . . .
steve mackay
but I've never seen this new page I'm a' type'n on. Must have kicked something loose. Lets try a pic . . .
Jack Guzman from Maine
That's about the way I felt when I made a walnut top for a side table completely with hand tools right to the finish. I didn't think I could til I did it.---Congrats---Jack
By George, I think you've got it!
Nice looking piece of wood.
