Re: Need help finding Windsor chair materials
scott grandstaff
Windsor chair making was a country thing.
There is no way in the world you are getting 1 X 16" X 10' sawed planks with a froe and a drawknife. Its just not going to happen. That was always a city thing.
Occasionally pit sawed planks were made for bridges and such, but mostly it was ax and froe work in the country.
The big sideboards and tall case clocks were predominantly city work where people could and would pay for sawed lumber.
Straight splitting wood is not something you just waltz in and get.
Its not like every log has it. Its more the kind of thing you stumble across as you are cutting and splitting a lot of wood anyway. You save back the cream as you run across it.
It is no accident that violins and all their parts can be neatly made from the very cream of 2' long stovewood.
Trying to split, shave and then bend a 6' long 1" square piece of wood into the looping spaghetti continuous armchair, and then drill 17 holes in it???
Well there are only a few woods in the world that will take that, and very very very few candidates from even those kinds of woods.
Buying a single log blind, and hoping??
Well the odds aren't very good you are going to be happy.
At best only one 1/2 of any likely log is going to be knot free enough for splitting anyway.
With every log there is a "light side" that once faced the sun, which will be full of knots (old branch stubs) and only the shade side is clear enough.
I took down a large red alder from my yard a couple years ago. Out of a full sized alder log, I kept 2, 3' billets, or 1/2 trunk sections, as suitable for splitting and working. The rest went into the stove. A whole tree!!!
The working green wood parts thing was another country trick. Split out a lot of green billets, whittle or turn them while they're still green and soft to remove most of the waste, and stack them in the attic for months or years to dry wholesale, finishing them as the occasion arose.
The warpers and splitters go into the stove.
There is tremendous waste, but then in the country logs are cheap and you need the rest of the unsuitable wood as firewood anyway.
With the very best stock its possible to get away with using some wood green straight away, and I know people have done it, but its not how it was done in centuries past.
Do the majority of work when its green and wait for the finish, much later.
If you took a full time job handling wood in the city. Tree surgeon, landscaping, power line work, etc, you would run across enough wood to select some working stock. Otherwise you would be better served taking advantage of things you can only get in the city.
Imported rare wood and veneers, big sawed planks by the thousand BF lot, stuff like that. You can't get that kind of stuff in the country.
Or you can just get off on the lonely freeway exit nearly everyone merely drives on past, going from city to city.
And take that road 50 more miles away from the highway, and settle down there.
You can have all the green wood you want, anytime.
But you will never sell your best split billets to a stranger.
You won't sell your best to your brother, they don't come that easy.
yours Scott
