OT - screw fastening into granite
I'm slowly working my way toward installing a bronze hook and eye to hold the back gate open (the original magnetic hold-open isn't enough in high winds). The hook will be fastened to a stone in the dry stone wall next to the gate. Someone at the hardware store discouraged me from using the plastic screw anchors, which leaves me thinking about lead anchors - actually, what appear to be aluminum inserts in lead anchors. Questions:
1. Will plastic screw anchors in fact be insufficient? They seem to me like modern versions of the rawl plugs of my youth, which worked fine.
2. If they will, I have some lead anchors with machine-screw-threaded aluminum inserts. If I'm using bronze screws, is there an issue with galvanic corrosion over time?
