Unfinished 5.5 *LINK*
Todd O. Cronkhite
Here is the 5.5 that I've been talking about. It's unfinished as you can see. The Tote, Bun and levercap are all mockups made out of 2x material. The design of the lever cap that you see is not going to be the one that finally gets used.
If you compare this body to the Jack, you can see the differences. This one is much better.
http://i400.photobucket.com/albums/pp89/ManofMaine/NewDesignX009.jpg
Re: Unfinished 5.5 *LINK*
Thanks for the pic Todd!
Scott Burr in Ben Lomond CA
I'd wouldn't have thought about prototyping the lever cap. Back to the drawiung board for me :\ .
What kinda square tubing do you start off with?
Please keep us posted and it matures.
Thanks again :)
Re: Thanks for the pic Todd! *LINK*
Todd O. Cronkhite
Welp, I dunno exactly what kind of square tubing it is, just mild iron common square tubing I suppose it is. The piece for the Jack came out of the dumpster, which pleased me greatly, however all the rest I have had to buy from a local ironmonger, which unpleases me greatly, >( but ahhhhhhhhhhhh well, so it goes.
http://i400.photobucket.com/albums/pp89/ManofMaine/NewIron002.jpg
Need to add a spot of info
Todd O. Cronkhite
If anybody should happen to decide to build an Infill out of square tubing be mindful that on most of the tubing, somewhere along the inside, there is a raised "seam" which if you aren't aware of will end up somewhere in your body, and just bugger the bejeebers out of you as you try to file it flat. :b Ya, ya, sure, I dare you to ask me how I know that. >(
So, when laying out your body design do ensure---if you can--that the seam is on the bit that will be completely cut away, which due to where the seam is on the tubing that I use for my Scrub planes, cannot be done. I think that the designer of the tubing done it on purpose just to annoy me, the rotten dog. ;)
Matt Prusik - NJ
Todd:
FWIW, that tubing is called "seamless" square tubing. Also known as Shelby tubing.
It is so strong, durable and versatile that it is commonly used (among other things) to build race cars.
Your plane has excellent metal ancestry!!!
Truly, a fine job.
Good luck and best wishes.
Matt Prusik
Todd O. Cronkhite
No problem Matt. Now then, looking at the pic of the tubing, the 5.5 came from the second one from the left, and the long skinny one* on the far right got chopped in half to make two Scrub plane bodies.
* that long skinny one was suppose to be that length, BUT as wide as the one that I used to make the 5.5 because I had visions of making a long Jointer. My ironmonger however, being the complete nit** that he is plonkerd things up and I ended up with this instead. Instead of correcting his error I merely said "ahhhhh Jolly good job, Thank- you very much" kept a stiff upper lip and bravly soldiered on figuring I'd slay the Jointer Dragon another day.
**an absolute great guy. If you met him on the street you'd swear that he's a complete bum who lives under a bridge, but come to find out I think that he is a borderline Genius and can only understand measurements in precise increments, so when I say to him "Oh, about this wide, this high, and this long", he hears "Oh, about this blah, this blah, and this blah. So therefore when Neanderthal me and Genius he are having a conversation concerning measurements, it only stands to reason that sooner or later the the Genius is going to screw something up. Well no matter, we get on quite well despite his shortcomings, and as much as he enjoys seeing me coming, I'm sure he enjoys seeing me going as well. :\
You know...
John in NM
You can get round tube as well, smoother than pipe...
I see a line of corebox infill planes in your future :D :D :D
Re: You know...
Todd O. Cronkhite
Oh trust you me John, I've been hoarding way some round stuff when I find it, as well as some angle stuff to make corebox planes. The round stuff I envisioned more as "gutter planes", and tho I can't think of much practical use for them, once you start using scrap metal for planes, then suddenly ALL scrap metal is planemaking material. Every day I check the scrap dumpsters for a new gem.
I can't wait for warmer weather to arrive so I can get started again.
