Turned my hand to tablelamps.
I suppose I should post these in the Turning Forum, but my friends are here.
This tablelamp (and its twin - I made two identical) is a rather simple design, but it took a long time to conceptualise. I never ceases to amaze me that the simple designs are the hardest.
My inspiration came from pictures of ships decanters. I love the flowing lines of some of the modern versions, and I could see a lamp in there somewhere.
I only have a little Jet mini. That and the wood I used - a salvaged (very, very dry) Karri (harder than Jarrah, interlocked, and stringy) roof beam - made this really strenuous work.
The Karri is nearly identical in looks to Jarrah - many find it impossible to tell apart. It is reddish-brown .. and Lynndy said she did not want any more Jarrah! So I added a black stain, finished it in oil and wax. The result is very dark, but the grain shows through. The pictures here were taken this evening, hand held camera and no flash, so they could be better.
I'd be interested in comments about the balance of height to width. Lynndy and I chose the shade(s) together, and she gave the pair her nod of approval, so I guess that is one more set of items to tick off the list.
Here they are - as I said, there are two, on identical tables, against identical sofas, set opposite to one another.
Thanks for looking.
Re: Turned my hand to tablelamps.
Patrick Gibbons
Derek, the lamps look to me like chess pieces a bit. My first reaction was that the shade did not fit the lamp as well as some other shape. The shade, often times, makes more of an impact than the lamp. I would have used a cone shape scaled to the lamp base. The lamp itself seems to be spot on for its curve and shape.
R.J. Whelan
Derek,
I've probably made 20 lamps over the past 40 years: not once have I been happy with the final outcome. Nor have I ever seen a lamp made from wood, either turned or assembled from linear components, that I found to be completely pleasing in form.
You lamp(s) are the first I've ever seen that are completely pleasing to my personal aesthetic.
You have built yet another piece that I will have to "appropriate" for my own home.
Thank you, again .... rj
Design critiques
... are slippery endeavors, Derek, because they're so subjective. I like the restrained form, the understated wood grain, the value and complexity of the color and sheen, among other things. I might have tweaked your curve a little differently, or undercut the base slightly, but those changes would have only made it different, not better.
I am curious, though, whether you used a "loader" (cast-iron weight) in the base to lower the center of gravity and resist tipping?
Cheers, and thanks for posting. It always takes a bit of courage to ask for comments.
Re: Design critiques
Hi Ellis
Thanks for the kind words.
I have planned to add lead sinkers into the base to increase the lower C of G. It is surprising how much stability there is already, which is due to the Karri, a very heavy wood (and the reason I turned the base out of this rather than an easier-to-use, but lighter wood). I have also thought to use a cork pads underneath as this will slide, compared to rubber pads, which will not. If bumped, I would want to lamp to slide rather than tip on this point.
Marv
Derek,
Anyone can make something complicated. I love the simple lines. What is more beautiful than the simple curves of a beautful lady?
Marv
That`s it!
Bob Hackett
I really liked the turned lamp base but there was just something...
As soon as you mentioned the shade I realized that`s what was what was throwing things off.
As you said Derek,the more simple the design the harder it seems to be to nail it down.I think you nailed it.
As Ellis said,a modified curve or a base detail would make it different but maybe not better.I`ve bookmarked the pics and will try a few subtle mods to add a twist to your fine design.Maybe shoot for a cross between your lamp base and one of Rudy Osolnik`s candle sticks.If it turns out near as nice as yours I`ll be pleased to say the least.
The lamp reminds me of a quote "Perfection is reached not when there is nothing left to add but when there is nothing left to take away" wish I could remember who I`m quoting.
I wonder how the lamps would look with shades from Norfolk pine or quaking aspen that were thin enough to let light pass thru.
MB
Re: That`s it!
Pam Niedermayer - Austin, TX
I had a software client once (a little scoring/average system for his golf cronies) who turned translucent shades. A little too wasteful for me, but boy were they beautiful.
Pam
A couple more pictures.
Here are a couple of pictures of the two lamps on the two side tables.
Incidentally, those two chairs were designed by my father (an architect) shortly before WW2 for a Swedish company. I restored them about 15 years ago.
