Pig sticker chisels - Buying Blanks
David Churnega
Interested in making a set of these chisels as it might be cost effective.
Where would you puchase pre-cut tool steel?
Re: Pig sticker chisels - Buying Blanks
Bill Tindall
I have made them. They are easy to make. Probably you will need to get the annealed steel cut at a machine shop. They can cut it quickly on a band saw or if you are patient you can cut strips with a hack saw and sand them smooth with a belt sander. Metal supply places will have steel, or you can order from MSC, or others. Actually the machine shop may have the steel. If you want the best buy CPM 3V.
More how-to *LINK*
Wiley Horne--So. Calif.
Hi David,
You may already have found this earlier post of Bill Tindall's, but in case you haven't, it is a good summary. See link below.
Wiley
How to make a chisel (Bill Tindall)
Frank D. in Montreal
Annealed steel is quiet easy to cut wit ha hacksaw. I use a grinder and hand files to shape it.
SOmething that makes life a lot easier is buying the blanks to fit the width of each chisel, but if you only need one chisel in each width, it can mean that you'll have leftovers that will really jack up the price of the project. If you actually use the steel for another project this can be justified. Otherwise, try to calculate the one or two thicknesses (blank thickness will eventually be the chisel width) that will be the easiest to grind down and file to width (well, if you only need a few chisels, you'll obvuiously have to buy steel for the thickest chisel).
