new fret saw
new fret saw
new fret saw
Catharine Kennedy
>This is a new, very lightweight aluminum fret saw that works a treat for cutting metal- the blade faces the operator and the material is moved into in- the support frame keeps the proper angle (90 degrees or whatever). So with all the plain metal, I couldn't help myself and started the embellishments... :D
Re: new fret saw
Someone needs to come up with a new phrase
>"Over the top" (in the most positive connotation of that phrase) seems SO inadequate.
I am reminded of the Edwardian machines, with carefully applied pinstriping added to beautifully finished castings.
Interesting tool, and your work on it will add a nice aesthetic bonus to the owner's day.
Re: new fret saw
Re: Someone needs to come up with a new phrase
Catharine Kennedy
>Since I am actually the owner, and this is the side mostly facing me, I'm real pleased!
Thanks for your comments!
Re: new fret saw
Re: new fret saw
Marv
>Catherine,
Very nice!
How does it work? Do you move the work piece up and down. It appears that the blade is stationary.
Did you buy it at a website? If so, can you share?
Thanks,
Marv
Re: new fret saw
Re: new fret saw
Catharine Kennedy
>http://knewconcepts.com/ is the site.
The support guides the fret saw which is moved up & down, in place, therefore the material is what moves forward or around, as necessary. Takes a bit of getting used to working this way, but much easier as it goes along!
Re: new fret saw
Re: new fret saw
Marv
>Thanks Catherine,
Would love to have one just because it's so different. I bet you'll make good use of it.
Your's no doubt works even better with the personal embellishments ;)
Marv
Re: new fret saw
Re: new fret saw
charlie belden
>What, no wriggling?
There was a time when all tools were embellished. I've played with cast iron kick presses with raised sculpted acanthus leaf patterns cast right into the cast iron. And most had a black lacquer finish - often with gold leafing "pin striping".
You are carrying on an old and wonderful tradition - and doing it very nicely.
So when are you starting on power tools - like the table top of a table saw - or an old
Big Enough To Land A Plane On Oliver joiner/jointer?
Nice stuff.
