Traditional Chinese Tools: The Toolbox
Chris Scholz
Chris Scholz
Chinese Toolboxes
Say you are a Chinese woodworker and, during your seven years of apprenticeship you have made a full set of tools. Because much of your work will be on site, you will have to find yourself a toolbox to carry your tools around.
Introduction to Chinese Toolboxes
Toolboxes are fairly complicated tools that must meet many often conflicting requirements. On one hand toolboxes must store and protect tools while they are not in use on the other hand, the tools must be easily accessible in the toolbox such that the work of the woodworker is not slowed down.
Much of the work of a Chinese woodworker was done on site. Cabinet makers (including their apprentice) were hired for a few weeks or months, ate and literally lived in the home of the contractor while working on the furniture. For that reason Chinese woodworkers had to carry their tools to the respective job site. In other words the Chinese toolbox had to be light and small enough to be transported to the jobsite as well as containing a complete set of tools.
History of Chinese Toolboxes
Chinese toolboxes have been around since professional woodworkers have been around. Obviously there is a need to carry an extended set of tools from one jobsite to another. In contrast to Western woodworkers where toolboxes at times became a purpose in itself, Chinese toolboxes never seem to have been elevated to that level.
Types of Chinese Toolboxes
Old prints of Chinese cabinetmakers at work often show tools that peek out of a woven bamboo basket.
The toolbox that I have seen in use at Liu Shifu's shop was a wooden box that contained all his tools with exception of the frame saws.
Liu Shifu's toolbox is not dissimilar to a Western toolbox. Compared to Western toolboxes Liu Shifu's toolbox is relatively small box. The box has a hinged lid that opens the top and a small drawer in the front and a handle on each side. The box has a padlock on it's front.
The lid of the toolbox has a simple bar that holds ten chisels in place. Two wide board divide the main box into two layers. Removing the front board shows that the drawer slides on two L-shaped rail.
The lid is well fitted to the box. As typical for Chinese carpentry corners are mitered. It is not clear what joinery was used to assemble the toolbox. It could also not be determined what type of hinges were used to fit the lid to the box.
Altogether the toolbox appears to be well-worn. It is very likely that Liu Shifu designed and built this box for his own use possibly from left over wood.
With the exception of the top edge of the box, Liu Sifu has as no moldings, carvings or other adornments of any kind. It is a simple well-executed box that is build for a single purpose: storing the tools of a professional woodworker.
Use of Chinese Toolboxes
As mentioned in the introduction, much of Chinese furniture was built at the customer's location. A major advantage of Chinese woodworking tools over American tools is that almost all woodworking tools had wooden bodies and hence much less weight than American tools. It is truly impressive how many tools Liu Shifu was able to store in a, by American standards, small toolbox.
Dallas, Fort-Worth, TX
