Finished a foot-powered lathe/sander...
John Aniano in Central NJ
>Hello All,
I have finished my new foot-powered watchmakers lathe with 8" disk sander. Although purchased in 1983, the lathe is basically new; I bought it new in Paris, France, while on vacation there with friends. It was made in Switzerland by Star. It has a lot of bells and whistles that I may or may not ever use, like the compound rest and graduated set of lathe dogs, but they looked good at the time, so I bought them. I have made a number of turned buttons for my bows with this little lathe using a motor and foot speed control, but it was really too fast for good work. I had always wanted to make this into a foot-powered unit, but never got to finish it until now.
I have to thank my friend Morgan Andersen, a fellow bow maker in Washington State for this idea. He has made several wonderful foot-powered clock making lathe setups that he and fellow bowmaker Peg Baumgartel use for making bow buttons. Morgan e-mailed me pictures of their lathes / sewing machine base drives and after speaking with both Peg and Morgan about their lathes, I felt I could do the same. So, thank you again Morgan and Peg!
Prior to creating this lathe/sander combo, I had seriously considered getting a hand-powered sander from John Alberti of Alberti Designs. The Alberti disk sander is amazingly slick! You have to take a look at this unit at www.albertidesign.com/sander and view this wonderful unit. I have seen this sander myself and it is worth the $$ - it is well machined and must be a joy to use. In my case, however, since I was going to make the lathe foot-powered anyway, it was natural to try to make the sander powered this way as well.
The whole system sits on top of an antique Singer Sewing machine foot-powered base, probably made for a commercial sewing machine. The base is different than those I've seen before and may be more powerful than the usual type. It has a pair of foot-shaped levers that when in use, are kicked causing the flywheel to spin. The levers follow the natural bending of one's knees. The levers connect to the flywheel through a complicated mechanism that has two curved gear racks, two pinions, two slip-ratchets all held together onto the main drive shaft. Complicated and a pain to take apart and clean - maybe a good reason why I've never seen another one of these before.
The pedals drive the main 5/8" diameter power shaft with the original Singer 16" flywheel/pulley, now mounted to the left side; I mounted a second, heavy, cast iron 20" diameter flywheel (a flea market find) to the opposite side of the main shaft, on the right. I had to make a 5/8" ID to 0.875" OD steel sleeve that joined the two. My SouthBend lathe and a boring bar came in handy for this task. A 6mm round pulley belt drives a 1/2" diameter ball-bearing countershaft on the pine top mounted to the Singer base. The right end of this countershaft has an 8" disk sander plate mounted to it. I got the plate from Grizzly Tools as a replacement part. I had to make another adapter sleeve � this time between the 1/2" shaft and the 5/8" bore of the plate.
In between the shaft bearings is an iron/aluminum 3-step pulley (yet another SouthBend project) that drives a 4mm belt that powers the little lathe. For this pulley, I copied the dimensions of the one on the lathe headstock. The lathe is continually tethered to the countershaft. Sometime in the future, I'll get a second small countershaft in between so I can take the lathe off the bench easily and store it in its wooden box "home" to help keep away rust. Until then, I'll use a clamp to attach the lathe to the table. When the 2nd countershaft is installed, I'll mount the lathe base permanently to the table.
The sander disk is at the other end of the countershaft. I made a wooden sander "rest" and vacuum port out of chestnut with a hard yellowheart top. I hogged out the internal waste with Forstner bits. The bearing supports are also chestnut (with 2 coats of tung oil). The supports and sander rest were made using offcuts from the trestle bench base I made last summer. In use, you have to pump with your left foot only to be able to reach the business end of the sanding disk. With a shop vacuum attached there is virtually no sanding dust. Now, if I could only vacuum the dust using foot-power�
When operating the sander, I have a belt between the 5" drive pulley to the 6" countershaft pulley. Although this gives a slower speed than when using the 16" drive pulley, there is a lot more power. The sander seems to work just fine at this speed and I have prepared a pair of cello bow frogs using the sander. I have sometimes taken the 4mm belt off the lathe pulley - it does make it easier to drive the sander alone. The 16" pulley works better for driving the lathe and gives spindle speeds in the low to mid 100's of RPMs with moderate foot pumping.
I have several viola buttons to make next and they will be a good test for the lathe portion of this new "power tool"!
Over and out,
John
