Hand Plane "hunting party"
Rick Snyder
>Hello,
This is a reply to Scott Burr's question as to what I found and bought with regard to my hand plane search. One Stanley #7, #5 and 2 Transitional planes, Bailey #35 and Stanley #29. The latter one's will need some work to get them in fine working order.
Rick
Re: Hand Plane "hunting party"
Jack Guzman from Maine
Transitionals
>The nice thing about transitionals is you can replace the body or put on a new sole without too much trouble.Also, adding a piece to the sole males it possible to close up the mouth.Transitional planes are much maligned but I was fortunate to handle a well tuned smoother once and gained a new respect for them.I also like the way they look.
The number seven is handy. I reach for mine every time I glue up wide panels.Even when I use power tools. The #7 is the last tool to touch them before glue.---Jack
scott grandstaff
Re: Transitionals
scott grandstaff
>The planes in Studley's chest are trannys. Except for the standard #1, they are all transitionals with what looks like custom cast bronze frames/hardware.
The most common serious complaint about normal Stanley and Sargent transitionals is that the tote wallows around in use.
Merely remove the tote, coat the bolt and frame with grease. Mix some epoxy putty and put into the base of the tote. Draw up the screw and wipe off squeezeout. Let it set.
It'll never shimmy again and yet can still be removed when you want.
The "frog" of a transitional is adjustable but you can't use it alone to close up the throat.
You can adjust if forward and add a piece of appropriate veneer to the ramp though. Stanley's brochure noted this.
yours Scott
He Shops, He Scores!
Scott Burr in Ben Lomond CA
>Nice haul Rick! Now all you need to do is clean and tune them up and show us pics of nice planes making fluffy shavings.
No Pic = no planes
VLParisian
>Without the evidence, this could be a tall tale or fable or ... maybe.
Show us the cash pic.
Victor - just messing around with you in Houston
