Re: Japanese scribing gouge...
John Aniano in central NJ...
>Wiley and Pam,
I use an incannel gouge to scallop out the sides of bow frogs, the ebony piece near the player's hand. The frog sides are roughed out with a gouge and finished shaped with a file and sanded/polished with abrasive paper, etc.
I have a set of #3, #4, and #5 gouges of various makers that I also use for this purpose, so yes, Pam, I do like the English and American gouges made by firms such as Addis and Buck Bros. I usually sharpen them with an ~35 degree bevel and pushing this through ebony is a challenge. You can only take small bites, so...
I wish to try something different and put the chisel tang, without a handle, in a non-spinning drill press as the downward motive force to more quickly rough out ~2.5" long frog blanks, and still call it "by hand". Some makers rough out using a router-type tool, some use a sanding drum to achieve the same effect. I thought that a Japanese scribing chisel, being shorter and with a round tang, might be the best kind of chisel with which to try this idea. Certainly a conventional "tanged" gouge would work, but the tang would have to be modified in some fashion in order to fit well into the drill press chuck.
I'll eventually find a solution - I just don't want to ruin a good tool trying an idea that might not prove useful.
Thanks,
John
John
