Freezing wood?
Edward in Vancouver
>My next project will be very utilitarian-- I have to make some new shelves for my stand-up double door fridge, and double-door freezer at work. These are commercial units, and the standard plastic-coated wire shelves are driving me nuts! Firstly the plastic is fatiguing and cracking off--in spite of only being a few yers old, and secondly, the wire shelves bend when they recieve anything more than 10-15 lbs, and then they pop out of the s/s channels that hold them in place.
So I was thinking of making wood shelves, aprox 3/4" thick and about 20" x 28", a frame basically of about 2-3" wide members with a center strip of the same and maybe 2 cross pieces--the shelves don't need to be solid.
Hardwood, but what? Soft maple is cheaper than Birch, and the shelves don't need to be pretty, just tight joints and "strong like tractor". I as thinking half-lap joints, maybe pinned with home-made dowels of the same wood. Finish is important--no film finishes, no toxic stuff, probably just mineral oil--re-treated when neccesary.
I need to make 12 of them, actually 14 would be nice. Humidity in the fridge would be around 80%, freezing temps in the freezer and the usual defrost cyles, so there will be condensation and water/ice forming on the shelves at times.
Does any hardwood stand up better than others in these temps/conditions? Would a decent outdoor glue like Titebond work? If provoked, I could use mechanical fastners, but I'd have to go to brass or s/s, and I'd rather avoid this.
Suggestions?
