a discussion of coped frame and panel joints
Bill Tindall
>I'll try again as the last try crashed.
One way to prepare this joint is to miter the interior molding as shown in the first picture. This joint is easy to prepare on a table saw as all the cuts can be reliably made repetitively with stop blocks.
At a class I took at the Mack Headley and Sons shop we leared another way that involves coping the molded part. I begin with three cuts on the table saw as shown in the 2nd picture. Again these cuts can be reliably mass produced on the table saw.
The rest of the waste is pared off with a chisel. To make the cope the area highlighted in white chalk must be pared off with a chisel and gouge, perpendicular to the face of the frame as shown in the next two pictures.
The final fit is shown in the last picture.
Some argue that the coped joint is better than the mitered joint because the coped joint will hide any opening of the mortise and tenon joint over time.
Well, I have tried it on 8 doors. It indeed goes quickly and it is not hard to do, but it involves carving tools which I don't have. I had to borrow the gouge to do these doors.
Would I do it again. Probably not as the miter seems to do well for me and I don't need to buy a gouge to do it. The joint shown first is 16 years old on a kitchen cabinet door and it is tight enough for me. However, if I was making the miter with a paring chisel cut I would not be as precise on the 45 degree angle as my table saw and a less well fitted joint would result. The coped joint would hide this shortcoming. Hence, which joint to use will depend on personal preference and not on the presumption that the coped joint is inherently better.
