Saw handle update
Saw handle update
Saw handle update
Edward in Vancouver
Hope I can get a picture in here.
Got the saw handle to a stage wher all I need is final smoothing and then a finish.
But what kind of a finish?
Regards, Edward
Re: Saw handle update
finish-oil
Bill Tindall
>If you intend to use the saw then an oil finish would be desirable. It won't look as pretty as varnish but it feels better.
While I don' t use a hand saw very much I have a canoe paddle or rake in my hands many hours a year. To what ever extent there is similarity, oil on wood feels better. Ditto for garden rakes, hoe, shovels, etc.
Marv
>Hi Edward,
Nice job on your new handle there.
As Bill said, oil will make the wood feel nice. Oil also makes it easy to renew the look of the wood from a maintenance standpoint. Just sand or steelwool it and give it another coat of oil. I use Boiled Linseed Oil.
Just using oil will not do the whole job of making it feel nice. You'll want to steelwool after the first coat of oil, then give it another coat, maybe steelwool it again and a third coat. I prefer a hand grip to be very smooth. I like to see the grain, but I don't like to feel it. Expect the BLO to take at least 24 hours to dry.
Another consideration is, do you want a light color finish or a dark color?
The pictures below is a handle made of Beech wood. I usually prefer a darker handle. I used dark brown leather dye and finished it with spray on Lacquer. No BLO on this one. Lacquer gives you a more durable finish and is easy to steelwool and respray it later after you have scuffed it up with use.
The handle is a restoration with several repairs, not a handle I made myself. The maker of this handle had painted it black. It was made by Disston owned company by the name of Jesse Lane. It's what I call a "sideplate" saw.
Have fun,
Marv
Bill Houghton
>Purty handle.
Edward in Vancouver
>Thanks gentlemen.
As you might have guessed, it is my third try. The last one I didn't center the kerf properly, and the first I got too "enthusiastic" with the rasp
DOH! I should have thought of oil, makes sense as the saw is not a furniture piece and will see some daily use. BLO it is then....
