Assorted old WW tools
Nathan
>Here's the auction I'm angling to win later on today. Not many people appreciate old hand tools around here, so I think I stand a chance of bagging it cheap.
Nathan
Bagged the lot for equivalent of $45!
Nathan
Congrats
Bill Houghton
>Those wood-screw C-clamps are interesting critters. I've got a couple of wood-screw bar clamps from my uncle - I assume, though I could be wrong, that he picked them up in his antiquing travels.
Nice drawknife on the right there, and another (on the left) that could use a couple of handles, and useful looking chisels.
I'm curious: there's what looks to be a long plane, top left in the photo. Between the tote and the iron there's an odd little construction. What is that?
Have fun cleaning them up and putting them to work. Bringing old tools out of retirement can be really fun.
Re: Congrats
Nathan
I haven't the slightest idea. Might be the handle is broken? Here's another view showing the jointer plane a little more clearly:
Ah - yep, broken handle looks right
Bill Houghton
>It looks like that originally had a closed handle - see the pic below.
Re: Ah - yep, broken handle looks right
J.Roberts
>Bill. I have a plane identical to the one you show here. It belonged to my dad. He died in 1953. It is missing the "guts" to it including the blade and a wooden fork type of thingy. Do you have any idea where I might get those parts to restore it? Thanks a bunch.
Not an expert in the wooden planes
Bill Houghton
>I have yet to get involved with the woodies, but some thoughts:
Check out the plane's body, and ensure that it's moderately straight - hold up a straightedge along its length on the sole and side. Then hold it from one corner of the sole to the opposite one. Look for light under the straightedge or rocking. You won't get machinist straight - it's wood - but if it's shaped like a boomerang it may be more useful looking pretty than being a working tool.
Also check the buttresses (not sure if that's the right term, and one of the wooden plane folks can sure step in here and correct me) at the sides of the mouth on which the "wooden fork thingie," the wedge that holds the iron in place, operates. If you see huge cracks or one or more is missing, again, it's a nice looking piece of wood to decorate your home or shop.
Let's assume it's kind of OK. You need the cutting iron. You need to know two things to get the cutting iron:
1. How wide is it? Measure the width of the opening, and figure that you'll subtract a little for the iron's width. Commonly, irons came in even fractional numbers, like 2" or 2-1/8" - I think.
2. Is it a single or a double iron? Look at the surface on which the iron will rest (bed). Is there a groove down the center about 3/4" wide, terminating before it reaches the sole? Then it's a double iron. If there's not a groove like that, it's a single iron. If you're not familiar with this terminology, do some research on metal planes for a comparison (look, for instance, on the Lie-Nielsen or the Lee Valley sites). Bench planes or bevel-down metal-bodied planes commonly have a double iron; block or bevel-up planes a single iron.
Note that, even if your plane uses its iron in bevel-down position, which it almost certainly does, it may have a single or a double iron - older wooden planes often had single irons, and some of the modern makers, like Clark and Williams, use single irons in their woodies.
Once you've gathered this information, post a "want to buy" or "looking" message on at least this forum, and maybe some of the others, too. There's someone out there with an iron that will fit. It won't be original, but, like putting replacement tires on your old car, you can run it just fine.
Wooden fork thingie is the wedge that holds the iron in. You almost certainly need to make this part, because you have to fit it to the iron and the plane body. I don't have much advice here, because I've never done one; I hope someone else can help.
Quick reply
>The wedge is fairly easy to replace - just make a new one. HOWEVER ... you can only do this after you have the iron. The iron will have a tapered thickness along its length, and this will vary from one to another (it makes it difficult to swap irons between planes with tapered irons). So get the iron first, then simply look at the gap left at the cheek.
Wedges can be surprisingly sophisticated in design ... just do a search on the internet/eBay for examples ... but I would start with a simple .. well .. wedge shape! Just follow the groove in the cheeks for guidance on the shape. Refine it as needed.
One quick tip to seat the wedge if it is not a perfect match to the cheek... Hollow the back of the wedge (rasp, file, sandpaper, beltsander) slightly so that it has a little "spring".
Re: Not an expert in the wooden planes
barryvabeach
>Jo Bill is right on in terms of sizing the iron and determining whether it is a sngle or double iron. Let me know the width, I have a couple irons lying around. Once you get the iron, you can make the wedge, though hopefully you have another plane. First, you get a rectangular piece slightly oversized, them cut or plane it so that its taper matches the slot. You then place it in the plane ( without the iron ) and you can mark out where the cutout needs to be to allow chips to clear the throat. Then you put the iron in and try the wedge - it won't be right, but using soot from a candle, or a pencil, or a feeler gauge, you try it, mark where it hits, plane that part off, then try it again. You are shooting for an even fit, but you only need it to fit snugly at the bottom of the iron near the sole of the plane and at the top of the plane, in the middle it can be a little loose and still work fine.
Re: Assorted old WW tools
Todd Hughes
>These tools all look like Europeon tools and more then likely recent imports. I see lots of these older Europeon tools, furniture and other stuff everyweek looking like it just came out of the barn. Apparently people are importing this stuff by the ship load out of Eastern Europe, I've been told that they bring over a container of stuff and cram it full since it's the same price for shipping since they don't go by weight.
Most I see looks like what is in your photo, rough and plenty used up.
$45 aint much money and if you just wanted some decorator stuff probably a good deal.....but if you wanted tools to use I think I would have rather have bought less none europeon tools that are in better condition....just me....Todd
Nathan
>Hi Todd, thanks for your thoughts. Indeed, I'm hoping to resurrect the planes and use them. Since I live in Eastern Europe, buying non-European tools is not really an option for me
- anyway, good eye! I was surprised to hear that old Eastern European tools are being imported into the U.S. Maybe that explains why they're so scarce over here!
