We value your privacy.
>Hi, I just won an auction for two pairs of forged dividers. They came from an old metalworking shop. One is 29cm (almost 12") and the other is 14cm (almost 6").
I guess the biggest question marks are the weight (comfort of use), plus whether they will hold a setting. They appear to be sharp.
>Like Jack, I use mine all the time and always looking for more. They shouldn't be too heavy, they are not that big and if the pivot is loose, wrap some sewing thread around the pivot between the arms, rather than tightening up the rivet with a hammer.
>I love 'em for repetition, transfer and places you can't get the ruler into. Wich, pretty much, describes my day. Have a 16" forged iron pair all the way down to a stray pair of Dietzgen drafting. Trick is to keep 'em handy. If they are in a drawer somewhere I didn't bother hunting them. Now they hang over the bench and I grab, set and go.
Old iron can be brittle and efforts to tighten the pivot rivet can cause metal failure, I know this from experience. The thread is easy and can be renewed with no problem. Rosin or brewers pitch in the joint will also cause enough resistance to solve loose leg problems.
>I have sometimes found tight joint calipers/dividers to be tricky - since you're adjusting by push/pull, you can spend a lot of time going back and forth between measurements. This may be a matter of practice, though - certainly, I've learned to set the iron on a simple spokeshave (Stanley 51/52) by guess through practice; no reason why it shouldn't work on the dividers.
I like Stephen's thread suggestion - that should provide some friction but without stiffness.
>Returning to the subject of the forged dividers - I received them in the mail yesterday (they are rather old, obviously made by a blacksmith). If you recall, I was worried they might be loose and I received some helpful suggestions on how to fix that.
However, while usable as-is, the main problem I see now with them is that they are too tight. I figure that will be easily solved with some lubrication, but at certain points in their range of movement they tend to "stick". In other words, the tightness is not uniform throughout the whole range. Any ideas on how to fix that?
>Assuming they worked smoothly at one time I suggest you treat them with electrolosis to loosen up and remove any small bits of rust.I don't recommend agressive cleaning however. Let the electrolosis work for awhile then scrub using hot water and a green plastic scrubbing pad. Then oil the pivots and move them through their range.Work the screw/screws etc.I use this method for most rusty tools. Others may have better methiods but this works for me.
If you're not familiar with electrolosis,there are a couple articles that will help you in Woodcentral's articles section.---Jack
How does electrolysis compare to a soak in vinegar as far as aggressiveness and is there any fear of loss of parent metal when using electrolysis?I`m aware of the hydrogen embrittlement concerns just wondering if the process may be safer long term than vinegar which is what I`m using now.
I did the electrolysis thing a long time ago and can`t remember why I got away from it.
I have never used vinegar for rust removal.I used it to age a piece of brass by fuming once but that's a different story.Electrolosis removes no metal. The rust separarates from the metal. Paint or platings will separate if there is rust between them and the metal however.So nickel plating will sometimes fall off. If you reverse the electrodes,that is a different story.Then you will lose metal.---Jack
Just soak your tool in it for a few hours and the rust goes away. It will leave a black substance inplace of the rust, but it is easily brushed off. The stuff is a bit pricey though.
Google Evapo-Rust so you can find where to buy it. I think Enco carries it in quart size.
As Bob suggests Vinegar is not a bad thing to try. It's cheap and easy to come by, but use the white distilled kind. Be careful with it though, it can discolor the metal if you leave the tool soak too long and it will cause pitting also. So soak it for an hour at a time, then clean it in water and wipe it dry.
Another thing that might work to make the parts move smoothly is to work a little grinding compound with a light oil into the joint. Work the tool until it moves better then flush out the grinding compound with more light oil.
Another thing to try is graphite. Locksmiths use it to loosen locks and make them work smoother. Sometimes you can find it in liquid form. I used to use it to make my lever cables work smoothly on my motorcycles. I'd squirt in the top end and it would quickly make its way down the cable and out the other end. This stuff works like magic if you can find it.
