Chinese Hammer: The Common Unknown Handtool
Chris Scholz
Chris Scholz
Introduction to Chinese Hammers
Anybody who has studied Chinese woodworking will not doubt have come across prints like this one where a ancient Chinese woodworker is depicted pounding on a piece of furniture with what appears to be the blunt edge of an axe. For example the Lu Ban Jing, a woodworkers manual written around in the 15th century, shows a woodworker assembling a table by pounding on one of its legs with the blunt side of an axe.
Chinese Woodworker using a Chinese Hammer to assemble a table
During much of China's long and colorful history, China has been more or less completely isolated from the rest of the world. Areas of extensive trade have changed hands with areas of almost complete isolation. For that reason many of the tools and methods that have been developed in China differ significantly from tools and methods developed in the rest of the world. So is it possible that all those years Western hammer collectors have missed an important tool in their collections? Have we Westerners been fooled into believing that Chinese woodworkers hit their chisels with the blunt side of an axe? Does there exist a tool that is used by millions of Woodworkers that we so far have been completely ignorant of?
History of Chinese Hammers
Like probably anywhere else in the world hammers evolved from what we tend to callprimitive wooden tools to our modern hammers. But is completely impossible for me to give a complete (or even basic) history of hammers in China, there is simply not enough information on the topic available (so much for an understatement). Instead I will focus on a very unique type of hammer that appears to be uniquely Chinese: the Chinese woodworker's hammer. I have absolutely no information how this type of hammer evolved, when it become popular and how it became the standard tool for Chinese woodworkers.
Types of Chinese Hammers
At first sight, Chinese woodworkers appear to use the blunt side of an axe to hit their chisels.
During the last few decades China has generated a tremendous amount of real wealth for its people and life has fundamentally changed for hundreds of millions of Chinese. Nevertheless the Chinese woodworkers appear to use exactly the same tool for hitting chisels as they did 600 years ago.
On closer inspection however, the tool that on first sight looks like an axe is everything but. This Chinese hammer is not designed to be used as and axe but is a Chinese hammer. The business side of the supposed axe is very blunt and most likely not hardened at all. Moreover Chinese axes consists of laminated steel where a hardened piece of steel is sandwiched between the main axe body. This clearly is not the case with Chinese hammers.
A West woodworker with a complete shop typically owns a great variety of hammers and mallets; Western hammers/mallets are made of a great variety of materials (hardened steel, unhardened steel, different types of hardwood, hard/soft rubber, leather, etc). The Chinese woodworker seems to be able to produce masterpieces with a single type of metallic hammer.
The Head of the Chinese hammer is a triangular piece of metal that is attached to a wooden handle. That's it, a utilitarian piece of forged steel in the shape of a wedge, very simple at first sight but highly refined when one drills deeper, just like the traditional Ming furniture that Chinese woodworkers produced for many hundreds of years.
Usage of Chinese Hammers
Since the head of the Chinese hammer has triangular shape there are two different facets that are used for different tasks. The short facet, opposite to the point of the triangle is used for roughing in large mortises.
Roughing in with a Chinese Hammer
The sides of the hammer are used for finer carving work and smaller mortises
Detail carving using a Chinese Hammer
Interestingly, the hammer seems to be held fairly close to the head, although I can not conclusively state that in some cases the hammer is not held further away form the head like Western hammers are.
Re: Chinese Hammer: The Common Unknown Handtool
Re: Chinese Hammer: The Common Unknown Handtool *LINK*
Pam Niedermayer - Austin, TX
>Very interesting, Chris, and very different from Vietnamese mallets as displayed in Joel's museum. BTW, I made and used the Vietnamese mallet, pretty cool in use. The only problem is you have to use denser wood to get a heavier mallet, or load it up with shot and/or stuff.
Pam
Vietnamese mallet
Thomd
>The modern framing hammer descends from a hatchet. I guess at the time the carpenter's hammers were all too light for sinking 16d nails in one swat and a bounce. For a long time after the framing hammer appeared, some framers stuck with the axe.
Christoph Scholz
>Yes, that would be conceivable but somewhat unlikely in my opinion.
Chinese housing construction relied on joinery and not on nails or pegs. So there would be no need to drive nails of any kind.
Framing with an axe
Bill Houghton
>Years ago, I competed (without success) for the carpenter's apprenticeship in this area. At that time, a rigging hatchet was a required tool for apprentices. The union official at the meeting made the statement that, at times, you needed a hatchet to trim irregularities sometimes.
Two handsaws were also required, ostensibly for things like trimming uneven rafter tails and other work too tricky to do with a worm drive saw.
Even at that time, small chainsaws were getting common on jobsites for those applications, so the information was a bit out of date; but, before chainsaws (and, now, I imagine, 24volt cordless circular and recipro saws), both hatchet and handsaw would have been quite helpful.
Thomd
>Heck, i'm not suggesting that the Chinese hammer descended from an earlier framing hammer, just giving an example of a similar use of the shape.
Bill, not so long ago the Can. mort. and housing authority was producing construction videos with the hatchet in them. They used to show up in FHB magazine also. By now we are at least three evolutions down the road in increasing specialization in hammers, though some people still swear by the hatchet for it's feel whether they would use one or not. Not to mention roofing and drywall hatchets, neither of which I have seen in use as hatchets, though they work fine for the nail-ups. We are in that case several tool evolutions down the road in alternatives for what the sharp end does. Yet the hatchets still come sharp.
Kinda wandering OT here, but...
Bill Houghton
>I've used the sharp edge of a roofing hatchet to cut the shingles with the corner of the hatchet. It's actually superior to a box/drywall knife for the purpose, because the handle serves as a visual straightedge - measure the length of the shingle to cut, put the moderately sharp corner of the hatchet head on the mark, put the heel of the handle down on the shingle at what looks like 90 degrees to the mark, draw the hatchet toward me to score the (back side) of the shingle heavily, bend the shingle to remove the waste.
It also means two fewer tools on the roof, a good thing on any pitch steeper than 4 in 12, where things start to slide if put down.
I consider the gauged shingling hatchet an example of perfection in design for its purpose. Having said that...we rented a roofing nailer for the 40x10 feet of roof we did in the Fall, trying to stay ahead of the weather (we failed).
I can picture using it to trim a wooden shingle or shake; I don't know how wood shingle/shake folks work these days.
Rob Lee
>Hi Chris -
We've been working on these (RH + LH) for more than a year now - and are just making the final forging die changes now...
Ours will have square heads (29mm), with a downswept cutting face. You can choke right up on the handle and almost plane with the head...the cutting edge is not perpendicular to the head axis....
The head is slightly curved, so that the bevel will always bear on the wood when the other end is touching as well.
They're a very interesting tool.
Cheers -
Rob
