Have I made an awful mistake?
Bill Houghton
>Long, probably unnecessary introductionLast summer, in preparation for finally wiring the shop, I moved a bunch of stuff out, including much of my wood stash, which wound up under tarps. Since the shop wiring was a precursor to remodeling our back bathroom (everything in this house is complicated - the original wiring to the shop was overhead wires that I need to get out of the way so we could tear out the outside wall of the bath, which had some rot), and since the bath remodel is now in month five going on six due to some surprise extra work, I am only now getting the wood back into the shop.
It turns out that blue tarps are not proof against 22 inches of rain, so I wound up thinning the wood stash quite a bit - a lot of the maple got too moldy to keep (and, no, it's not big enough to let go to spalting so I could turn it, if I had a lathe), and some of the other wood too.
Finally getting to the pointI slathered the stuff that seems to have survived with a 50/50 mixture of laundry bleach and water and set it up on end to drain before stickering it on the shelves at the top of the shop. I know that chlorine doesn't last long in liquid state (since I need to add chlorine every second day to the hot tub), so I didn't bother to wash the wood after. Was that a mistake? Does the chlorine bind to the wood in some way and create a harmful chemical reaction if left unrinsed, or will it evaporate from the wood just as it does from the spa? I figure I'll need to plane the wood anyway when I use it, so assume any damaged cells on the surface will just get planed away.
