Fret Work Tray
Fret Work Tray
Fret Work Tray
Bill Tindall
>This piece involved a lot of fretting, mainly because I had never done anything like it before- fret work, bracket feet, inlay, chemical staining.
The assembly is quite complex. The inlay, alternating bands of satinwood and mahogany, is glued together like a butcher block and then sliced to make a veneer band. This band is applied to a backing which comprises the center of the side. A strip of solid wood is glued beneath this inlay strip. A strip of 3-ply homemade plywood is glued atop the inlay strip for the frets and finally a strip is glued around the top to hide the plywood edges. The bottom is snug fit homemade plywood to add strength to the piece. I found some nice ribbon stripe to resaw for the bottom.
Someone, I can't recall who, suggested the frets be cut from "plywood" to add strength to the delicate fret work. Indeed, this approach added strength, at the expense of needing to deal with the plywood edges. Some of my catches with the fret saw would have undoubtedly broken some of the fret work had it not been plywood. Normally such a tray would be dovetailed together but I chose posts to hide the plywood edges.
Staining is a problem because one wants the stainwood to remain unstained. The traditional way to deal with this problem is to stain with some sort of basic material- lye, lime or ammonia. I chose ammonia. Now that some sun has hit the piece it is browning up nicely from its initial red hue. ork Tray
Re: Fret Work Tray
PS, a thank you
Bill Tindall
>A lot of people helped with advice on this piece...thanks to all of you.
Re: Fret Work Tray
Re: Fret Work Tray
Wiley Horne--So. Calif.
>Bill,
That is amazingly graceful and well done! I can't believe how clean all that fretwork came out.
I'm pretty sure it was Warren who said to make up the fretwork blank from three plys. By the way, 'plywood' has a certain meaning in woodworking which does not apply here--you are talking about face gluing three plys of _mahogany_ aren't you??!! Or maybe I have it wrong.
Can you tell us how the four 'walls' of this tray are joined together, and how that ties together with the four posts? Also, will you tell us how are the bracket feet attached to the bottom of the tray?
Truly a stunning ornament to light up a whole room!
Wiley
Re: Fret Work Tray
Re: Fret Work Tray
Dean J in MN
>Lovely work Bill!
-Dean
Re: Fret Work Tray
Re: Fret Work Tray
Hank Knight
>Bill,
That's really nice. I've been curious about this project since I first saw your posts about it. You put a lot of thought and work into it and the result shows it was well worth it. Very nicely done.
Hank
Re: Fret Work Tray
WOW!
Scott Burr in Ben Lomond CA
>This piece would have drove me nuts to make. Glad to see there's much more patient people out there than me. Well done!
Re: Fret Work Tray
Inspiring work.  Thanks for showing us
Bill Houghton
Re: Fret Work Tray
Re: Fret Work Tray
Pam Niedermayer - Austin, TX
>Beautiful, Bill. How did you deal with the plywood edges revealed by the fret saw?
Pam
Re: Fret Work Tray
Re: Fret Work Tray
wilbur
>Really nice work, Bill!
Re: Fret Work Tray
Re: Fret Work Tray
Bill Tindall
>they are more or less lost in the shadows.
Re: Fret Work Tray
answers and foot detail....
Bill Tindall
>Can you tell us how the four 'walls' of this tray are joined together, and how that ties together with the four posts? The sides are mortised into the posts. Now, after spending a multitude of hours assembling the sides, the making of tenons on their ends was a bit stressful.
The post ends were done on a shooting board. It turned out to be easy with mahogany.
Also, will you tell us how are the bracket feet attached to the bottom of the tray? Glued to bottom. I would like to add a nail, but unwilling to risk nailing this frail structure. Note that the corner glue block is made from "1/2 plywood", that is the plies are half inch thick. This arrangement relieves the cross grain stress in this blocking. It is made by cutting the sub-blocks and assembling them in place with rub joints. I carved the inside of the block round to give it a finished look. People want to pick the tray up to examine it so I thought the bottom needed to be more finished than a chest of drawers.
Re: Fret Work Tray
Awesome
Ron in Kokomo
>Bill,
I have done a little bit of this stuff, so I know what it takes.
Very nice work. Thanks for sharing it with us.
Ron
Re: Fret Work Tray
Wow!
Tony - Memphis
>Looks great Bill. Nice work on figuring it out and completing it.
Tony
