Problem with Primus Try Plane
CJ in MPLS
>I was recently given a problem plane and have been trying to figure out how to get it to work. I think the plane may have some stripped threaded parts, but I confess that it may simply be because I don't know exactly how the Primus adjuster works.
In any case, once the blade is in I'll loosely tighten the rear nut to secure the blade. At this point I try to get the blade to its desired position. If the blade needs additional adjustment (it always does), I'll use the depth adjuster to move the blade to its desired depth and lateral adjustment. At this point the problems begin. The loose hold down adjustment must be tightened to keep the blade from retracting during use. I know this as I've tried to use it with the looser adjustment to no avail; the blade will simply retract. Once tightened, the blade will again need fine adjustment, which is difficult to achieve as the depth adjuster seems to have difficulty overcoming the friction between the blade and the bed. Similarly, I experiences something with the hold down knob that feels like it is stripped as after tightening to a degree, it will seem to loosen. The confusion seems to stem from my suspicion that both the later/depth adjuster AND the hold down mechanism appear to be stripped as I cannot isolate this behavior to one or the other.
So, am I attempting to adjust this thing correctly, is there some indicia of proper set-up that I am missing, and/or do I need to consider how to replace the adjuster and/or hold down? If it is a write off I suppose I could have my 8 year old paint a pastoral scene on it and sell it as an antique. Do scenes of zombies and vampires fighting in a cemetery count as pastoral if more than one tree is depicted?
CJ
Re: Problem with Primus Try Plane
Wiley Horne--So. Calif.
>Hi CJ,
Here's what to do. And it's what every single Primus plane owner needs to do at some point. Take the mechanism apart. First, you will be able to see plainly if there is stripping of either the depth adjuster screw, or the hold down screw. Second, you will see how the mechanism works, which is very important, because what actually happens is counterintuitive--but it all comes clear once you see what is going on.
So unscrew the holddown nut in the rear, and then also begin unscrewing the depth adjuster. You can fully unscrew these, and take the mechanism out, along with the blade/backiron assembly. It's a little fiddly, because of the way the holddown catches the blade assembly, but you'll see how to get it all apart.
Here's what you will find:
Holddown Assembly.....Holddown nut has a threaded insert in it. Then comes a washer (don't let this fall in the shavings), and then a stout spring which sits in a recess. Threaded into the nut, and passing through the washer and spring is a lever (steel bar). This steel bar has a crosspin at the end of it, and that crosspin goes through the blade assembly and catches on the backiron. So when you tighten the nut, the lever pulls the blade assembly back--and slightly up--with the spring maintaining lots of tension.
Depth adjuster......Totally unscrew this until it comes out. The depth adjust is threaded through a threaded insert in the plane body. Looks like a good 1/2" of thread engagement.
The way it all works.....The depth adjuster pushes down on a small indent in the holddown lever. Yes, the depth adjuster rod pushes on this other holddown lever, and forces it down--that increases the blade depth in the work. But it also tightens the holddown! It pulls the holddown lever against the stout spring. And then similarly, when you retract the blade, the depth adjuster releases some pressure on the holddown lever, which in turn rides up, pulling the blade with it. So you see, there is this mechanical interaction between the depth adjust rod and the holddown lever and its spring. This will only become clear to you when you see it all pulled out. What I do is use the depth adjust rod to get the blade in the ballpark, and then use the holddown nut for fine adjust! You have to go back and forth between these two to get it just right in the initial setup. BTW, those two polished steel domes at the top of the bedding are there to reduce the friction between blade and bed. The iron is not bedded on wood, but rather against those two domes. You'll be able to judge whether the two domes need filing or a dash of oil.
What to look for....When you get this mechanism apart--and don't worry--you can't hurt anything--you will see directly whether there is any thread stripping on either the holddown lever or depth adjust rod. You should also be able to peer down into the threaded inserts in the holddown nut and the threaded insert in the body for any evidence of stripping.
Some thoughts....if there is stripping on the depth adjust rod, it is long enough that you might be able to saw off the bad part and still be in business by grinding a new conical end on the rod. On the other hand, maybe you get it apart, clean out all the jammed shavings etc, find that nothing is wrong, apply light oil, and all is good!! I think there is at least a 50:50 chance that this is the case, because the internal mechanism of these planes is pretty stout, with long thread engagements. Oh, when you get the plane back together, it is the red side of the holddown rod that should be facing up.
I find the ECE planes to be excellent, and excellent value. They just have this non-intuitive depth adjust mechanism.
Wiley
CJ in MPLS
>Thanks for the response. I'll give it a shot.
No comment on the zombies? ;)
CJ
Pastoral scene requirements
Bill Houghton
>There needs to be at least one cow or bunny, too, preferably not a zombie or vampire cow or bunny.
No zombie comments
Bob Hackett
>You might say it`s a dead issue.
MB-Ducking and running to the nearest cover/concealment.
Mike Real in PGH
>Another thing to look at is the cross pin. Mine has a slight bend in it. When I tighten the rear nut, it pulls the blade crooked in the mouth. THe lateral adjuster sometimes has to be swung way over to get the blade centered evenly in the mouth and the tensioner nut loosened. They are sweet on wood with a little bees wax on the base.
Now that was a brainless comment!
Bill Houghton
Zombies = pastoral *LINK*
wilbur
Well, Jane Austen is kind of pastoral, and there's this book, so I guess the answer is yes, zombies are pastoral. ;)
Available on Amazon
I have that on my request list at the library
Bill Houghton
>The title is just too good to resist.
The young woman who pointed it out to me says that the book does not hold up to the promise of the title - she was most disappointed.
Re: I have that on my request list at the library
Bob Hackett
>Try "World War Z" or "The Zombie Survival Guide",two of my Goth son`s favorites.I actually found "WWZ" to be a pretty good read but then again I liked "Cell" by Stephen King.
MB
LOL!
Pam Niedermayer - Austin, TX
Zombie warning
CJ in MPLS
>A word of warning: if you stay up late reading the zombie survival guide, you will not sleep for trying to plan for the zombie apocalypse. ;)
Also, the Austen zombie book is much funnier in concept than in execution.
CJ
Update on Problem with Primus Try Plane
CJ in MPLS
>I had a bear of a time disassembling the Primus plane. The problem turned out to be a bent depth adjuster. In trying to adjust the depth, the adjuster had slipped off of the retention rod that extends to the back of the plane. Subsequent attempts to get the depth properly adjusted had driven the end of the depth adjuster past the rod some distance, bending it. The weird behavior of the depth adjuster was a result of the bent end of the adjuster coming into contact with the retaining rod as it turned.
As it appears that the only threads holding the adjuster into the body are made in the wood, I'll see if I cannot purchase a new, straight adjuster in lieu of trying to straighten the existing one. I wouldn't want to damage the threads in the wood any more than they are.
Thanks,
CJ
