We value your privacy.
>Been practising with my new PAX crosscut and realized the handle is uncomfortable and ugly to boot, a new handle is on my mind. I don't have any apple on hand and the beech I do have is finger jointed and laminated. What I do have on hand is some teak that's almost an inch thick and almost 7" wide. I do have oak, but I'd have to edge joint it, and I'm not so sure about that.
>I made a handle from cherry because that is what I found in the kindling container. I was in the same situation. I had a wonderful hand saw but the handle was made for King Kong. I copied a handle that fit my hand nicely from an old saw. Because I like the feel of the well fitted handle in the hand I use the saw more than I otherwise might.
I don't see why any close grained wood wouldn't do fine for a saw handle. You should have birch and maple readily available.
>I made some handles for iron stone carving hammers for a friend of mine and they held up fine for that application.He said the thing he likes most about them is that they still have some "traction" even when his hand sweats during work.I made a few chisel handles for myself after his report back and found he was right.
I have no real world experience with using teak as a saw handle but will be using more of it for chisels and hammers.
One word of caution,most all the teak I`ve worked has been very abrasive(I`ve seen sparks off my lathe chisels) and rather tough on blades and edges,especially tailed tools.
>I've made two hammer handles out of teak, both broke, just under the head. One was being significantly abused (dropped through a skylight hole onto plywood floor below), but I doubt very much that hickory would also have broken.
However a hammer is not a saw (obviously), and I don't feel that you would have the same problem. Like Bill and Bob, I've found teak to be a good wood to grip, I like it a lot. I've seen mesquite saw handles that Mike Wenzloff made and was surprised that mesquite didn't break too easily, as I've found it more fragile than teak on the whole.
So I'd say give it a try, could end up being your favorite saw, or you could end up making a new one. Either way I'd say you're ahead, as practice is always a good thing. I'd love to see a picture when its done!
>As to the wheat carving, Marv Werner may be able to explain its historical significance.
I recall reading something somewhere sometime on the subject, and what sticks is the notion that it represented prosperity - but that could have about as much validity as most of my dreams, which combine random synaptic firings in ways that would have caused Carl Jung to give up his research on dreams and take a job selling deep-fried cheese balls from a cart in Basel.
Google did not help me in trying to confirm or refute that idea.
>I agreee the handle is too large and ugly. I've thought about replacing the handle on my saw, and my first thought is to take the old handle off, modify it, and put it back on.
This would save me the difficulty of sawing the saw blade slot in the new handle, which I think might be a bit difficult to do accurately.
>My hands are a bit small, and the stock Pax handle is made for large hands. That being said, I'd still like to take a rasp or something to the handle as it has potential, but it is still too big for me.
In any case I'm going to give the teak a try. A neighbor threw out a teak table that had split down the center. He must have kept the leg assembly, but the split top was about 3' in diameter and just shy of 1" thick. Funny thing is, I found out the "hard way" that the boards were edge joined and pinned with some very thick nails at the factory. My cheap-o stud sensor did pick out the other nails, but only after I ruined a sawblade finding out that there were nails in there...
Wheat carving is merely embellishment and serves no purpose as to the performance of the saw. It was originally done on the more expensive saws such as a Disston No.12 for example and was done strictly by hand. Later when the embellisment was done with a motorized cutting method the saw companies did it on cheaper saws as well, but I don't think of that method as "carving". Starting around the 1940,s or so, the so called wheat carving was so sloppy on all saws made during that time period, it couldn't even be considered embellishment. In my opinion, it detracted from the over all look of the saw, if that was even possible.
As for the type or species of wood you can use for a saw handle, most anything will do. Make sure it is thoroughly dried so it won't shrink and crack after you've done all the work. When you do the lay out the grain should be horizontal so you will get the strength through the small areas, like below and above the grip hole.
The slot for the blade can best be sawed by hand using a RIP filed backsaw, one with a thicker blade or any fine tooth rip saw that will cut a kerf the thickness of the blade you have for the handle. I've used my bandsaw a couple times, but I can do a more accurate job of it by hand because a bandsaw blade will tend to wander off the line.
Sometimes you can just reshape a badly made handle and make it feel better in your hand. The reason they make the grip hole bigger is for those who might want to wear gloves.
Below are some pictures of a Disston 1940ish D-8 that I customized. Those were butt-ugly saw handles in those days.
The wood in the top picture is the same as in the second picture. The second picture is a "before" picture of the handle in the top picture. The wood is Beech.
Started already and have cut out the basic shape. By looking at various blogs I understand there are two methods of mking the slot for the blade. Th first is the one you describe and the second is to clamp the sawblade down perpendicular to a bench and "saw" the handle by moving it into the saw plate. Not much is said about the "hang" of the saw plate, but since the fctory set up is good, I'll try and mimic it as much as I can.
>On handsaws - that is, not backed saws - the general practice is to set the handle so that a 90 degree line through the handgrip part hits at about the midpoint, front to back, of the sawblade.
Some of the literature I've seen suggests the same for a backsaw, but, if you actually analyze the hang on backsaws, it seems to vary between that setting and an angle that points toward the heel of the blade, with the latter being far more common with shorter saws.
>I am sure you could use teak, it is comon in boats, and outdoor furniture, which means it is both workable (abrassive as mentioned), and strong. I find it not all that nice to look at in small pieces, and too light and open grained, but it is certainly an option if you don`t have something more appealing.
