Marking off of your workpiece rocks
wilbur
>I know this is probably not news to most of you, but for me today was a great example of why it's always better to mark off of your workpiece instead of marking to an arbitrary length. I cut the tenons for my long stretchers for my workbench today, and one of the things I needed to mark off was the length of the stretcher. Problem was, I knew that length was going to be over four feet long, and the only thing I had that would measure a length that long was a tape measure, and I didn't trust my ability to measure accurately with a tape measure by myself.
So instead, I mocked up the position of the legs as they will be when the bench is compete, and used that to figure out the length of the stretchers. I had made a mark at one end of the stretcher to represent where the shoulder of the tenon would eventually be, and lined it up with the edge of the leg.
And then I was able to see on the other end where to mark for the shoulder of the other tenon.
The result: I was able to accurately mark the length of the stretchers to within the accuracy of a pencil line, even though they were 53-13/32" long, and all I would have been able to use otherwise was a tape measure. And here's the result.
Re: Marking off of your workpiece rocks
Joe McMahon
Joe McMahon
>Wilbur, I like it!! Nice job even though you use those inferior "eastern" saws. ;)
wilbur
>Hi Joe,
:D
That's a little 210mm ryoba I used to cut those tenons, which are 2" long, and just about 3-1/2" wide. To put things into perspective, the blade on this ryoba is a bit shorter than the Lie-Nielsen dovetail saw. Now imagine using a dovetail saw to cut these tenons. ;)
Gotta be careful
Ron in Kokomo
>This works is your mock up is dead solid perfect. Get just a little out of level or plumb and you got trouble.
Re: Gotta be careful
wilbur
>You bet that I triple-checked the setup before I marked it. ;)
Bruce, a MN Galoot
>I've gotten myself out of trouble bunches of times by following exactly that procedure, Wilbur. The only thing that equals it in my practice, anyway, is laying out a story stick. Once the overall dimensions are set, I lay out a stick and work out things like rail widths, tenon lengths, etc. And the beauty is I can pick it up and take it across the shop.
Can't wait to see that finished bench. You'd better finish in situ, because you're not going to be able to move it.
