A Thicknessing Technique *LINK*
>I have written a couple of pieces on �four squaring� and thicknessing by hand, and these are on my website. Here I want to describe a technique that I recently began using when thicknessing boards. I have not seen it elsewhere, but I am very aware that I am likely to be re-inventing the wheel.
For this article, please access the link below ..
Re: A Thicknessing Technique *LINK*
steve mackay
>I'll have to remember that one. Is that the home-spun #3 infill getting a workout ? Do you still like the angle ?
>Excellent, Derek. I don't recall if it was Toshio Odate or Simon Watts who first taught me that chamfer trick, but it was so elegant that I've used it ever since. Thanks for yet another excellent tutorial.
Frank D. in Montreal
>Hi Derek,
Nice article as usual. Your collection of articles is becoming very interesting for people starting out with hand tools, better than any one book.
I learned the chamfer trick from Charlesworth. :)
Alan Schwabacher
>It looks like a good idea. Roy Underhill describes cutting rabbets at the ends, and using the winding sticks in these rabbets. Then after a flat surface is defined, he cuts out the middle surface down to the rabbets. The advantage of this approach is that it works for the first side as well, and with rough hewn stock not close to flat. Since he described it, I assume it was in common use a couple of centuries ago.
Dean J in MN
>The rabbet method is shown in Roubo (or was it Felebien?) if I recall. I'm trying to find a link to the plate showing the method.
Dean
ThomD
>The one thing about that would be how does one cut the chamfers to be flat unless the whole board has already been evenly thicknessed. I can imagine a clever little plane that would fence off the finished side... To some extent that is what Charlesworth achieves with his gauges that have either left or right bevels.
Hi Thom
The point about thicknessing - whether by hand or machine - is that you always level one side first.
Scribe the thickness from the face side.
Chamfer to that line from the waste side. The "trueness" of the chamfer angle does not matter (some have been hung up on this) - all that matters is that you can see the finish line (that is, the chamfer hugs the marked line).
