Have a question? Ask Woody!
Hey -- remember that workbench I was working on?
wilbur
>It's been over 9 months since I did anything meaningful with the workbench I started building last January. I finally got around to finishing the joinery for the legs. I had cut the mortises before, but this past weekend I cut the tenons and drilled holes for drawboring.
I'm going to use double mortise/tenons to attach the top to the legs. Here you can see the hole for the leg vise screw to pass through. In the previous picture you can see the slot for the parallel guide at the bottom of the leg.
I'm sure I'm going to lose major hand tool cred points here, but the holes for the leg vise screw and the drawboring were drilled using a combination of a drill press, cordless drill, a 3/8" brad point bit, and a hole saw. Why? Because overall I kind of suck at precision drilling. ;)
A picture of the dry fit. The side that I'm working on will actually be the underside of the workbench top, which has served me surprisingly well as a worksurface. I probably would not have waited 9+ months to get going on this, otherwise.
And, the other set of legs.
It's amazing how much you can do if you have a holiday weekend when (1) you're not on call, and (b) said holiday does not involve eating large amounts of turkey or Santa bringing presents for the kids, in which case you also have to deal with visiting relatives. ;)
Next step: cutting the long stretchers and tenons. Given my rate of progress in the past, I'll have that done by mid to late April. ;)
Re: Hey -- remember that workbench I was working on?
Paul M.
>WOW Wilber! That looks great! :) (I get to use smilies now!!!)
Those are some seriously huge legs. I can imagine the desire to beef up the one leg that will work as a leg vise. Having the other three legs match is going to make this the most bomb-proof bench ever. It definately won't be walking across your shop under heavy planing!
Stephen Shepherd
Stephen Shepherd
>Will you be able to get it out of your shop if you move?
Nice work.
Stephen
Wiley Horne--So. Calif.
>Wilbur,
It's looking great!! Very handsome and clean joinery! That's a nice herd of saws you're working on.
Wiley
Bob Entwisle in NJ
>Hi Wilbur,
Your bench is coming along nicely.
The joints look nice and clean and tight.
And it's HUGE! It'll be great to have such a solid bench to work on.
Bob
Looking muy bueno.  Me likes it.
Victor Parisian
The secret to clean and tight joinery
wilbur
>The joints look good, but I'm really being selective about the camera angles I use. ;)
Stuart Hough
>Your leg lokk GREAT Wilbur...er...I mean the bench legs 8). your'e Speedy Gonzalez compared to me. My bench seems to be stuck in place for now. Keep up the good work!
Victor P
>Did you really chop those front stretcher motices in the leg? I cut mine on the table saw before gluing up the leg very fast, neat and clean. (except for the leg where I flipped the morticed piece around ...oops Kind of looks like I left a spot in the workbench leg to stash a pack of cigarettes.)
Victor
Soft focus lenses can help too
wilbur
>I did chop the mortises by hand. That was kind of crazy, but part of the reason I did it was that I was semi-dared to do so by Wiley, and as he mentioned to me back then, now that I did it I can go around saying that I did chop out 1" wide mortises by hand for my workbench, which is kind of a cool thing to be able to say.
I posted about my mortise chopping back when I did it. Once the archive search for the new version of WC is in place, I can go back and find it, and post a link.
Re: The secret to clean and tight joinery
>When we sold off my parents' place, there was some 19th century furniture that got distributed. It was the first time I'd really looked at it as an adult, and I was surprised to find how sloppy the drawer dovetails were - but the drawers still held just fine.
Tight, clean joinery is a good thing; but, in some cases, over-rated as to its structural necessity. My son says the trick is to know which standards to maintain and which to let slip. That, of course, is another of those life-long lessons 8) .
Alan Schwabacher
>Here's a similar lesson. The Dean of students gave a presentation when I was a freshman (over 1/3 century ago) at which he pointed out that going to college is an exercise in selective neglect. "You can't do everything, but you'd better choose very carefully what you are not going to do." It was surprising to hear, but I found it true.
It holds for woodworking too.
