Sheep tallow
Paul Londo
>On one of Roy Undehills shows he made a grease box that he had filled with sheeps tallow . Why? Anybody know the benefit of using this form of grease on metal?
Sheep tallow
Paul Londo
Re: Sheep tallow
Andrew F in Australia
>I used to use it as a lubricant when cold rolling steel at about a rate of 5 tpd or so, Paul.
When stored indoors, steel didn't rust for about 6 months or so.
I'm guessing that it was an original anti-rust treatment, which could be why Roy Underhill uses it.
Pure supposition on my part.
Cheers,
Andrew
Re: Wool Grease.....
Jesper, Denmark
>.....is full of Lanolin, very good for your hands.
Re: Sheep tallow *LINK*
Roy Anderson
>I'm sure there are better things to use nowadays. You have to be into reenactment to seriously want to use sheep tallow. It is the fat from the carcass of a sheep, not the lanolin from it's skin secretions. Sheep tallow is said to be more brittle and hard than beef fat and also has an unpleasant odor and is not used much as a food stuff. Therefore, I'm guessing that it was cheap and readily available for industrial use. It would put a water barrier on the steel and also lubricate it. I'm guessing it would turn rancid pretty quick, also.
technical description of sheep tallow
tallow is not Wool Grease.....
Bill Tindall
>Now we are discussing a topic upon which I have some practical experience. Wool grease comes from the wool. About half the weight of the raw wool is wool grease and wool grease contains lanolin, which is not a fat or oil, nor is it chemically even remotely similar. Wool grease is the sheep's rain coat, no doubt inspiring the oiled cloth out-back fashion. Note sure why it is called "grease" as it is appears as small liquid droplets on the wood fibers. Where it not for the other accumulations on sheep wool it would be nice on the hands petting sheep. (They don't bath often and in general lack in personal hygiene)
Tallow is sheep fat, which like all natural fats and oils are fatty acid esters of glycerol. The "best" tallow comes from the kidney fat and if someone needs some the timing is poor as my wife just put the last of what we saved in the bird feeder. We will have some more in the spring when we start killing lambs.
Re: Sheep tallow
Stephen Shepherd
>I don't use sheep tallow as I don't like the smell, now real beef tallow that is good stuff. I however use lard, stores nicely and doesn't go rancid unless heated.
I also mix 25% lard and 75% beeswax in my grease cup for nails, screws, etc. I mix 10% lard to 90% beeswax for candles that burn bright and long. The straight lard can also go into a grease lamp for inexpensive lighting.
Stephen
Organic rust preventative(and weight loss aid)
Bob Hackett
>Well maybe the sheep tallow is why Roy goes thru guests to his shop so fast.;^)
I`ve found that the mineral oil and bee`s wax I use on kitchen utensils
works pretty well on hand tools too,both wood and metal.
Sure smells and feels better than tallow.
The wife and I were in the check out line and had 2 suet balls(We cover them in seeds for the birds) up on the conveyor.A curious shopper from further south looked and asked why we would buy something like that.I told him we were planning to fix them for supper.Further explained that while they may look strange and unappetizing they were actually very good at keeping your weight down.He brightened up and asked how we prepared suet.With a surprisingly straight face I managed to say"Why,we deep fry it,of course".
He not only didn`t get the joke,he left the line and headed back to the meat department.
The cashier,who knows me,said she`d clue him in when he came back.I thanked her and went on my way.
MB
A new treat at the county fair
>Our local county fair deep fries Twinkies - why not suet?
Re: Enlightening.....
Jesper, Denmark
MN state fair
Bruce, a MN Galoot
>I don't know how other fairs operate, but there seems to be an ongoing search for the newest fair food that can be deep-fried on a stick. Just take ordinary food and add a half-cup of grease.
