Frey Brace
Frey Brace
Frey Brace
Doug Reynolds in Seattle
>I recently took possession of a Frey brace that needs some TLC. I took the top knob off and it appears the bearings(?) underneath are not accessible. It turns just fine but I was wanting to clean it up. As a last resort I just gave it a quick shot of WD40 in what seems to be an oiling hole. Is there anyway to get access or, do you think the WD40 is enough?
Re: Frey Brace
Fray Brace
David Miller from Iowa
>If you can get it perfectly functional using lube from the outside, there is no need to get inside. DAMHIKT
Re: Frey Brace
Re: Frey Brace
Phil Joines Krum,Tx
>WD40 is not a lubricant. Get a can of White Lithium spray at a auto supply or the borgs.
