Help ID Unusual Level
David Miller from Iowa
>Picked this up today. Split down the middle with a very fine adjustment screw on one end that expands. The other end isn't hinged - just a metal plate that flexes. Like a grading level, but the graduations and length of travel are for too fine.
No makers mark. ideas on maker and use? Thanks. David
Re: Help ID Unusual Level
Paul M.
>No ideas on the maker. As to the usage, I'm laying out concrete forms in my yard and want to have a small degree of angle for drainage. This would allow a simple bubble to have a known rise/run ratio by tweaking the gap between the two boards. Modern levels have calibrated bubbles with multiple lines to accomplish the same rise/run calculation.
Just a guess, but seems plausible!
In shipbuilding...
Bob Hackett
>That would be known as a declivity level.
They were used to level things on ships built on inclined ways and set from a known surveyed benchmark on the boat.
MB
