Saw Sharpening Question
Tony - Memphis
>I boought a nice little backsaw recently from an online fella we probably all know. The saw is in good shape except that the last person that used it thougt it was a hacksaw and tried to cut metal with it! I'm assuming that but the teeth are all bent over pretty good. How should I approach sharpening this thing? I'm just learning to sharpen and not very good. Not sure what the best approach is with this one. Do I need to file it down past the "curls?" I'd like to slap the person that mistreated this poor saw! I may send this one out as it has pretty fine teeth and I'm not even rookie status sharpening yet. I have some much bigger saws to practice on. My thought was to file this one crosscut since I already have a good rip filed dovetail saw.
Thanks,
Tony
Re: Saw Sharpening Question
Dean J in MN
>Tony --
Just approach it like any other saw you need to recover the teeth on. Joint the teeth, and work on shaping them. I'd suggest doing this in multiple passes, don't joint too large of a flat, just work your way toward "good" teeth bit by bit. The gurus out there may joint quite a lot off the teeth and essentially retooth the saw using only the vestiges of the base of the gullets, but if you are just starting up the learning curve doing this in multiple passes is a easier task.
In cases like this I work every tooth-pair, skipping no gullets, until I get the teeth in reasonable shape again (i.e. I shape the entire sawplate from one side of the saw). Don't worry about fleam until all your teeth are back in shape. Once the teeth have "grown" back, joint lightly, and go about your regular sharpening routine.
You'll be able to do this, just make multiple passes and joint lightly between them.
-Dean
wilbur
>That's probably a perfectly good saw to practice sharpening on. You can't make it any worse.
Seriously, Joel Moskowitz once said something along the lines of, "a poorly sharpened saw will still work better than a dull one". So have at it!
Re: Saw Sharpening Question *LINK*
Marv
>Hi Tony,
Have you read Pete Taran's tutorial on sharpening saws for beginners? He pretty much explains everything you need to know.
Keep in mind that setting of the teeth is equally important as filing them. For a backsaw such as yours, you will only want a small amount of set. .003 or .004 per side.
I usually set the teeth right after reshaping them and before filing the rake and fleam angles on a crosscut. After I have the angles filed, I will lightly joint one more time and do a light final touch up. Then I set the teeth again. After the final setting, I slide a slip stone across the sides of the teeth, both sides, not much, just enough to make all the points even. Maybe only two light swipes. Don't use a file for side jointing, too easy to remove too much.
Pete includes a reference chart so you can determine the size file you should use.
Dean is right, best to joint and shape in several stages or passes. When you shape the teeth, use the same rake angle that you'll use when filing the rake and fleam angles. For a crosscut, a 15 degree rake angle and a 25 degree fleam angle is good for general purposes. When shaping, you'll only be filing the rake angle.
Have fun,
Marv
Pete Taran on how to file saws
Joe Rogers, Northern Virginia
>I would try a different attack on this issue. I would lightly tap the teeth from the bent side to straighten them and remove most of not all of the set and damage possible. This would "raise" the points as much as they could be raised and this saves metal. This saves work...and this is good :-)
Then the next step would be to join the saw to just touch all points and then sharpen as necessary. Reset as required and enjoy.
JR
Thanks!
Tony - Memphis
>I'm gonna give it a go when I finsih my curent project. Probably a week or so. I reallylike the saw. I hope I can make something out of it. I'll probably work on the handle and clean up the metal a bit as it looks pretty rough. Thanks for the help and encouragement. I'll be back when I start working on it I'm sure.
I've got Mr. Taran's info and several others and the DVD (Mr. Law?). Got some files too. I have an old vise, but it doesn't clamp too well, so I'll probably make one.
Tony
Marv
>Tony,
It is risky to bend teeth that have already been set in order to reduce excess set or for any other reason. Saw steel is not very mallable. Some of the older saws are quite brittle. A tooth that has been bent once does not like being bent in the opposite direction and then being bent again when resetting after sharpening. It is always safer to do a little more filing to correct a problem with the set. The small amount of metal that is lost due to a little more filing is better than broken teeth.
Marv
Heed the voice of experience Tony.
Bob Hackett
I have a saw that illustrates your point
Bill Tindall
>Well, actually it is missing the point....several of them.
>Saw vintage wasn't specified in the OP and the fact that the teeth points curled didn't lead me to believe the metal is that brittle...but I've been wrong before. Surely if the damage was worsened by the attempted repair I would back up and regroup. Good points in debate though and worthy of mentioning!
JR
Re: I have a saw that illustrates your point
Marv
>Hi Bill,
My guess is, 98 percent of missing handsaw teeth happened during setting of the teeth. Some saw filers turn blue due to holding their breath while setting a 10PPI 26" saw, for example, hoping to not hear that deafing "plink" sound. You'd think that oversetting would be the cause, but not always. I never overset teeth and it will still happen even with minimal set. So, if a saw has too much set and you attempt to hammer the teeth so they have less set, that's just inviting some broken teeth. The best and safest way to reduce excess set is to file it out.
Marv
