Brackets for tables
Patrick Gibbons, Katy, TX
>The type of bracket that folds out to support a table leaf. How are those connected to the rails or the top?
Brackets for tables
Are you asking about a gate leg table?
Bob Hackett
Re: Brackets for tables
>I've never made one, but I've seen picured two solutions of fold-out brackets:
1. metal hinges attached to a vertical member and a tall table apron, pretty common on "colonial" reproductions, and
2. wooden pintle hinges - think of a boat rudder made entirely of wood, with pins at the top and bottom rotating in little brackets.
As Bob Hackett mentions, the gateleg table solution is also available, with a leg hinged using either method above and providing direct load path to the floor.
Of course, you can also make sliders that pull out through slots in the top of the apron and hide under the main table top when not in use. One of the problems with sliders is leaf sag, which seems to get solved one or both of two ways: a) mounting the slider so that it rises as it pulls out, b) putting a little block of wood under the leaf at the slider's end when pulled out, thick enough to compensate for the sag.
All this is theoretical knowledge on my part; I will now shut up and let people with more experience talk.
Warren in Lancaster, PA
>There are a lot of methods but execution is what is important. The best ones work so that the brace wedges the leaf upwards as it is extended.
One method has a large triangular brace that has pivots on both the apron and a stretcher below.
Another has a long cut out in the top section of the apron and a batten fits in the cut out portion. There is a pin coming up from the apron in the middle on which the batten swings. Part of the batten goes out under the leaf and part swings in under the table.
Some have slats that extend through a slot in the apron and push back under the table when not in use. Some have hinges attached to the apron. If the hinge is just a little crooked, the arm will tighten when it is nearly all the way extended. The gate leg is probably the strongest and most reliable.
Stephen Shepherd
>Patrick,
One traditional method is to use a knuckle joint [pivoting finger joint] that doubles up the apron to which it is glued; pegged, nailed or screwed. The free end folds flat against the apron when not in use. To use, lift leaf and fold out the free end to support the leaf.
Some old tables have long thin tapered wedges glued to the underside of the leaf and the bracket pivots out until the leaf and table top are flat.
Stephen
