Beats a froe!
Beats a froe!
Beats a froe!
ThomD
>I've been tempted...
http://www.youtube.com/watch?v=Kldc_R9yfmQ&NR=1
http://www.youtube.com/watch?v=3SUuUzAieig&NR=1
Re: Beats a froe!
Re: Beats a froe!
Dominic in Buck's County PA
>While I like the creative use of black powder in relation to spectacular explosions as much as the next guy (well,....,maybe just a BIT more!), that seemed a bit excessive.
I'm guessing this method is used on BIG logs with super tough wood. Or out in the rough when there isn't a chain saw bar big enough to handle them!
Re: Beats a froe!
Makes you wonder...
Bob Hackett
>If trees are carelessly dropped it can damage the wood.Small splits and shakes can be induced that cause excessive waste during drying.
I can only guess the kind of stress and hidden damage that blasting cranks into the mix.Don`t know if I`d want to pay for the boards that came from the big trees processed by this method.
I knew a guy who used to cut damaged ax handles off flush with the head and then drill one hole big enough for a blasting cap into the remaining wood.He`d insert the cap,cover the ax head with sand bags and blast the remaining wood out.I always wondered how long those ax heads lasted till the stresses involved finally led to failure of the steel.
People with access to blasting material seem to look for ways to apply their(sometimes questionable) skills.Sometimes the bigger hammer isn`t the best tools for the job after all.
Mainely,Bob-Former Army demolition specialist
Re: Beats a froe!
Re: Beats a froe!
ThomD
>What a bunch of killjoys!! I mean sure, don't do it in the den...
I'm not sure how serious they were about using the wood, since there seem to be rather a lot of these videon on YT for it to be a serious endeavour. More like those people who blast anvils into the air. :(
That said, I used to rock climb in this quarry outside Dublin. It was quarried using gunpowder, and the result was that rather than shatering the rock as happens (look at some roadside cuttings), when high explosives are used, nice big chucks were cleaved off due to the gental push of the black powder. So maybe the wood wouldn't be all that badly affected. Hey, remember that mythbusters episode where they built the canon out of wood? They considered the myth of overnight construction busted because the drill bit didn't work. But the canon did. They should have read Walter Rose on the drilling.
http://www.youtube.com/watch?v=AJgYtt99V5s
Re: Beats a froe!
Well,in that case...
Bob Hackett
>They didn`t use NEAR enough powder!
I would suggest a switch to TNT(or plastic) over powder and multiple charges connected by a ring main and double primed.
LET`S MAKE SOME KINDLING!!!
MB-Hand me that 10 ton sledge.
Re: Beats a froe!
Re: Well,in that case...
ThomD
>They need the large version of that thing that presses out french fries!
