We value your privacy.
>I recently found an old henry disston & sons mortise gauge that feels good in your hand. I use the crown brand which is fine. The pins on the disston stand about 1/16 inch and should be replaced if I want to use it. How do you get the pins out? BTW I really like the smooth action of the stem screw to set your mortise width. Makes the crown seem primitive.
I have only done this once, and the most difficult part was removing the iron screws holding the brass where the fixed point is located. Once I removed that I pressed the stub of a point out the back side of the brass piece. I then shaped a large steel needle to fit in from the back side until it projected the correct amount. A little peening of the brass made the steel needle fast.
If the point doesn't move try penetrating oil or heating and freezing the piece. The difference in the shrinkage coefficient of the two metals can sometimes loosen the pin. If I were to try it today, I would first treat it in an ultrasonic cleaner.
>Stephen, thanks for your response. I see what you mean about the screw fixing the fixed pin. My screw slot is buggered and depth is lost from wear. How did you press the pins out? My thought is to back the brass spine with a steel plate with drilled hole to allow pin to pass. Then press in vise or hit it with drift pin of smaller diameter.
In your original post, you mentioned that the pins were about 1/16". Have you tried using it? The pins on modern gages are usually much longer than necessary. Typically, pins this size work fine if sharpened correctly, they should be sharpened like a knife rather than a cone. You should be able to find some information about sharpening a marking gage on the net.
That sounds like a good plan. I think the pin is inserted from the back side. I would do the heat/cold thing first, then test to see which way the pin comes out.
>Jim, the fixed pin was pulled to increase length and I could sharpen that one. The sliding pin is around 3/64th inch above brass and rounded over. That screw backed out only after I filed a fresh edge on my screw driver. Wish I could find a new screw but it's so small I'll have to reuse it. I've deepened the slot with a Dremel. Not the best but it's serviceable. I like Stephen's suggestion of heat. Thanks, Ken
