Veritas - Innovation in Tools
help with some spalted hackberry.
Victor Parisian
>I got a nice piece of spalted Hackberry for my birthday several months back, and have been eyeing it for an upcoming project. It is one piece 7/8" thick 2'long by 3-1/2" wide. I want to use slice it into veneer on some drawer fronts. Do I attempt to stabilize it in any manner before sawing it to thickness or do I just go for it. How many pieces of veneer should I be able to get out of this? Pics to follow.
Regards from Houston,
Victor
Re: help with some spalted hackberry.
Back from errands... here are the pics *LINK*
Victor Parisian
>This is the wood. hopefully it shows well enough.
Spalted Hackberry
Wiley Horne--So. Calif.
>Victor,
That is a stunning piece of wood. Never seen hackberry before--is it really as white as holly, like the photo shows? Would you have these drawers looking out of a dark case? Jewelry box comes to mind, ebonized something, with a small Shaker type ebony pull for each drawer.....Would you cockbead the drawers, and if so, in the hackberry or in the case material? It's an interesting project.
If it were me resawing it, I would use a bandsaw and would set it up so it would saw 3/32" on scrap. Face joint the front and back faces. Take one 3/32" slice, which gives you a smooth face and a sawn face. Then face joint the stock board again, and take another 3/32" slice, so now you have two slices, each with a jointed face and a sawn face. And so forth. You get however many slices you get--an expert could do thinner than 3/32" prolly, but I would feel confident at that thickness, allowing for the need to handle the wood without it falling apart, and also the need to plane/scrape the sawn side once it's glued on. Maybe you end up 1/16" finished thickness. When you glue up, glue the smooth face to the drawer front stock--the sawn face is the appearance side. Then plane the sawn face. I wouldn't do that gluing til all the dovetail joinery was done though.
You get however many slices you get. And that defines the number of drawers you can make.
I'm curious how thin others would saw that wood.
Beautiful piece of drawer front veneer!
Wiley
Pam Niedermayer, Austin, TX
>Hackberry is treated like a junk tree here, but I like it, very white/yellow.
I think with this spalted piece I'd first apply some sort fungicide, being probably overly careful with these things.
Pam
Victor Parisian
>Yes, it is definitely considered a junk wood. My brother had one blow over in his yard a couple of months before Ike hit last year. He cut it up and just left it laying there for several months before he got around to gathering some up to bring into his shop to dry. Last spring he took a four foot log and cut into it to see what the wood was about. At first he was disappointed because it looked ruined. What you see was just one piece of the result. He has some more that I can go pick up on Christmas day.
>Cool, maybe I should cut into some I have laying about. :)
Pam
Victor Parisian
>Thanks Wiley,
Yes Hackberry is very white. As white as Holly? Don't think so, but close. E-mail me, I'll send you a nice high resolution pic or maybe an actual sample so that you can see for yourself.
I just lined up the spalted Hackberry next to some English Sycamore, some soft maple and a piece of American Sycamore, and you are right, it is rather white.
Victor
ThomD
>I would probably go for what Krenov calls "real veneer". Not sure where he got that idea. Anyway, it is pieces 1/8" thick or better.`It is nicer to work with hand tools. If making half blind dovetails it is thick enough to use as the face of the drawer without the risk of the pins showing through the venner as uneven. Of course thinner wood is also probably thick enough for that. I would say though that going too thin has probably ruined more projects than going thick. Resaw a similar piece first to see what you can do, and not just what others say you should be able to get out of it. Also, you may want to work with some matched pairs. If so saw the wood in half first. Clean up those pieces, then saw each in half, with as little waste as possible. You will have two pairs of matched wood, if the staining cooperates.
I used to buy turning wood from supliers. I would bring it home wet and put it in plastic bags to keep it wet. If it wasn't turned soon it almost all splated. I never had any problems with the rot and my lungs. Normal care around dust should be fine, though it's hard to actually say that the way people are these days. Given how it prgresses on almost any kind of wood, hard to believe the source isn't all around us. I don't smoke though, or otherwise have compromised pulmonary function.
>All around us? Not necessary, since fungi spontaneously generate. :)
