Re: How do you get that perfect grind?
scott grandstaff
>Hey Hey what wavy grinding??
Its hollow and smooth both sides, meets right in the middle. As If! Sheesh
The bevel runs to the edge at the very tip but tapers toward the top for added strength.
Nope no jig, no nothing. In fact I didn't even have great footing from some assorted mess I didn't get all the way cleaned up. :)
Cheap old grinder, very coarse wheel, 1/2 a coffee can of water for dunking. Took maybe 20 minutes. Maybe a bit more.
Hold the tool in your bare hands. Use the tool rest to rest the backs of your fingers on, so you can feel it at all times.
Keep the blade moving at all times.
You can swing to one side lightly and heavier on the bad side you need to even up, but keep it moving regardless or you'll burn it.
With hollow grinds guys, its a feel. You feel for it.
You take the first pass totally blind, so you try to put it in the middle of where you want to be, and some material removed, but not too deep.
Then lift it free and see what you did.
For the next pass you find the path you made by feel. -Very- lightly address the wheel with your antennae up, and "feel" for it by rocking slightly until you drop into the pocket. You'll find it.
Now dig in and grind, but always moving remember. You can cut some pretty good steel with a coarse wheel as long as you keep it movin.
Now where was it off?? Which side do you need to "lean' against. Its always one or the other. So you lean toward that side without leaving the "trough" you just cut.
Not totally leaning, stay in that pocket, but just a lean will start moving you back to center as you grind.
2 or three more passes and take another look. You can alter the pressure as you go in case the tip is too thick or the butt needs it more.
But stay in that trough!!!
Don't finish the first side all the way. Go to the second side and start there. You bring the shoulders even and the cut to the middle from first one side and then the other.
You may think you will never get it. No way!!
Stay with it, Buddy Boy!!
You'll find it.
yours Scott
