Brace vs Hex Adapter
David Miller from Iowa
>I need a quick and easy way to use hex power driver bits in a brace - ideas? Doesn't have to be pretty, just functional
Re: Brace vs Hex Adapter
Wiley Horne--So. Calif.
>Hi David,
There are a number of braces that will take hex shanks directly, as well as round shanks, in addition to Morse taper. Some of these are Yankee 2100/2101, Stanley 923, Millers Falls 732/733 and Lion chuck 772, Stanley 813, Pexto 'Samson' chuck....undoubtedly others.
Maybe I'm missing something in the question?
Wiley....who recommends Yankee braces, North Bros. or North Bros./Div. of Stanley, all made in North Bros. factory in Philadelphia
>Thanks Wiley, but I have (insert ridiculous amount) of braces - all 2 jaw. I would rather have some adapter than buy a new brace.
Re: Brace vs Hex Adapter *LINK*
>I assume you mean the 1/4" power drive bits. Two jaw chucks with sharp jaws will grip a hex bit, although not, in my experience, terribly well. I'd put one of those magnetic hex bit adapters in and tighten up well, so you can slip different types of bits in.
If your braces have had a lot of miles, you may find that the tips of the jaws are pretty rounded off, in which case, you probably won't be able to grip the hex bits well or at all.
If you have access to welding gear, you might be able to make one, although any magnetic grip or spring loaded grip is likely to get ruined by the welding heat.
If you have a little money and need an excuse to put in a Lee Valley order, they sell an adapter for this very purpose, see linky below.
http://www.leevalley.com/wood/page.aspx?c=2&p=32300&cat=1,180,42337&ap=1
Minor clarification re two-jaw
>Hi David,
All the braces I mentioned are two-jaw--the little v-notches in each jaw grasp opposing arrises of the hex shank. I do it all the time, driving the hex shank bit directly.
Course, if all of your brace herd are Morse taper only, then you still need the adapter, like the LV one that Bill pointed to.
Wiley
me too- no porblem
Bill Tindall, E.TN
>I stick the hex points in the jaw groove and never gave it a second thought. With this arrangement I have driven and especially undriven screws out in the pastures like on gates and such. It is the only way to drive the big screws, awesome torque.
I remember the first time I gave my then 10-year
Bruce, a MN Galoot
>son a brace and a screwdriver bit and had him drive screws. He, of course, wanted the cordless one (I pointed out that the brace had no cord), but he was delighted at the power he had with the brace/phillips bit combination. My two jaw chuck (reminds me of a cheap wine) held the bit just fine.
Bruce
Re: Brace vs Hex Adapter------WebKitFormBoundaryKC *LINK*
Old Baleine------WebKitFormBoundaryKC9lpOiB+3EckMp
>Check out "C."
------WebKitFormBoundaryKC9lpOiB+3EckMpA
